Old 31st January 2006, 01:08 AM   #1
msharpe is offline msharpe  United States
Default New to building, need some advice.
I recently decided that i want to upgrade the speakers on my old stereo, and I wanted to do it for a small price. So I'm trying to figure out how to build an amp. I plan to use a pair of 150 watt 8 ohm woofers, four 8 ohm speakers, and a pair of 60 watt tweeters. Theese are all things I've found surplus, so I don't have all the specs on them. So basically, I've been looking around the net and in some books, and I've found a schematic for a class B amplifier that looks very simple. It's basically an NPN combined with a PNP transistor. I'd imagine it's really inefficient, but will something like this work for me? I planned to build an amp for each set of speakers, so 6 at least, and then wire them all in parallel to a power supply. Does this sound like it would work? I know that I'll need three way crossovers, but can I put two speakers on each midrange section?
Old 31st January 2006, 03:26 PM   #2
Speakerholic
Cal Weldon's Avatar
I'm not any help with the amp but you can use 2 drivers for the mid section.
Its pretty tough to design an XO if you don't have the parameters of the drivers. Without them it's pretty much hit and miss, with miss being at the forefront.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st January 2006, 03:54 PM   #3
Did it Himself
richie00boy's Avatar
Can you post the schematic for the amp? It is just not possible to build a usable audio power amplifier using just an NPN and a PNP.
If you are on a budget I would just say buy a used amp and speakers. Active is the best way not necessarily the cheapest way.
As Cal said without parameters, your speakers are pretty useless, but the good news is that you can measure them yourself.
Moderator - Cal must have been asleep as he left this thread in the Subwoofers section, it would be better in the Loudspeakers section would it not?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 31st January 2006, 04:09 PM   #4
Speakerholic
Cal Weldon's Avatar
Thanks Richie, I have moved it.
Old 31st January 2006, 06:19 PM   #5
Well here are the schematics i've got, they're pretty rudimentary, just copied form a couple places. The bottom right is what is supposed to be a class B amp. Click the image to open in full size.
From how things are going, It's looking more and more like I might just buy rather than build an amp
Old 31st January 2006, 06:42 PM   #6
Did it Himself
That link is asking me to join to see the pics.
Old 31st January 2006, 07:35 PM   #7
OK hopefully this lik will work Click the image to open in full size.
Old 31st January 2006, 08:23 PM   #8
Did it Himself
Nope just the same
building a Zobel (RC) need some advice. Serratoga Multi-Way 1 22nd April 2009 07:26 PM
Advice for Building Modula MTs gee_boi Multi-Way 23 6th February 2008 05:00 AM
Building the Karlson K12 Need advice fin1bxn Multi-Way 0 29th January 2007 02:30 PM
building new towers, need advice mrray13 Multi-Way 11 23rd August 2005 01:53 AM
Building a new HT system, need advice Mr Pookie Multi-Way 4 11th January 2005 07:21 AM
Page generated in 0.08932 seconds (76.52% PHP - 23.48% MySQL) with 10 queries
