Old 30th January 2006, 04:45 PM   #1
eag is offline eag  United States
Default Speakers - Brands
Hello. I am a newb to all this a didn't quite know what to search for so help me out (I tried a search but just got technical stuff). I was wondering how reputable some brands are, or where I could find a listing or so on this.
I want to build some computer speakers, so I was checking out the only place I know (could you recommend some?) to buy some speakers - partsexpress.com. However, I don't recognize the brands they offer (like Goldwood, pyramid, etc.) Could someone tell me if these are good brands and if their small speakers sound good?
I'm just looking around now and was thinking of making a box with one of their amplifiers you mount to the back of a box and connecting the speakers to that.
Let me know what you think.
Old 30th January 2006, 05:09 PM   #2
Speakerholic
Cal Weldon's Avatar
Default Re: Speakers - Brands
If they are just for your computer, do you want some full rangers?
[i] I don't recognize the brands they offer (like Goldwood, pyramid, etc.) Could someone tell me if these are good brands and if their small speakers sound good? [/B]
Those two are budget speakers but can still sound good. You might want to check out the Tangband stuff at PE as well. I have used their products and am happy.
[i]I'm just looking around now and was thinking of making a box with one of their amplifiers you mount to the back of a box and connecting the speakers to that. [/B]
Most of those boxes are plate amps. Those are restricted to low frequencies only. There are some full range amps out there for use in active PA speakers but I can't seem to find it on the PE site right now.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 30th January 2006, 07:41 PM   #3
Do you recommend full range? I would just have them play my itunes music and the occasional DVD.
I actually did find a tang band I think would work. It was a 3"driver with 110-20K range. I think that will suit me just find until I add a small sub of some sorts.
http://www.partsexpress.com/pe/showd...number=264-813
Thanks for pointing that out about the plate amps. Shame, I really like the options I had with them. So what would you recommend for a full range amp? I'll need 25rms into 8ohms.
Also, whats another place like partsexpress.com?
Old 30th January 2006, 10:17 PM   #4
AJinFLA is offline AJinFLA  United States
Banned
EAG,
25watts (RMS) @ 8ohm is much more than most economical "computer" speakers come with.
http://www.madisound.com/cgi-bin/ind...19885&pid=1621
Sells drivers also.
http://www.apexjr.com/Dual25FR.html
Inexpensive, but a bit large.
http://www.mcminone.com/product.asp?...5Fid=55%2D2590
Source for drivers/amps.
FYI, TB speakers can be found in brands like Logitech
http://newsite.pagecomputers.com/sto...ct%5Fid=297844
probably for less than you could build them for.
AJ
Old 30th January 2006, 11:53 PM   #5
Thanks. I will ask more about amplifiers in the correct forum.
Big can caps brands? HaLo6 Everything Else 6 25th March 2009 08:09 AM
should there be less brands in audio? paba Everything Else 15 26th July 2005 03:25 PM
Different brands:Is there any difference? specter73 Tubes / Valves 8 10th June 2005 05:59 AM
speaker brands kalts Multi-Way 2 28th June 2004 11:11 AM
Speaker Brands guitargully Multi-Way 5 16th December 2003 08:56 PM
Page generated in 0.08494 seconds (77.63% PHP - 22.37% MySQL) with 10 queries
