Old 30th January 2006, 12:57 AM   #1
Default wmtmw driver spacing
I know the maximum between drivers of an mtm is determined by the distance of the wavelenght at the xo point.
Within that limit, is it best to keep the drivers as close together as possible or give them some space.
The reason Im asking is that I want to make a WMTMW version of Vinces VHT with the dayton aluminum drivers. Estimating that the woofer to mid XO is at 400 hz, and assuming I have the formula correct (distance of the wavelength=speed of sound(33300)/frequency in hertz(400)) I calculated that the maximum distance allowable between drivers is 83cm. I think that the D'appolito white paper says that woofer to tweeter, but even if its woofer to woofer, thats still more then the 69cm sum total of the driver diameters.
69cm is pretty small, and the VHT speaker is WAY bigger than that. Of course its a MTMWW but the mids alone are probably in the range of 69cm. So why is this speaker so tall? Is there any advantage?
I assume the best thing for me to do is to just squeeze the drivers as close together as possible, which is what Ill do if no one gives me a good reason not to.
Besides I might put a sub driver at the bottom of the cabinet to really get down low.
Old 30th January 2006, 12:59 AM   #2
and here's the link to the VHTs
VHT's
Old 30th January 2006, 05:48 AM   #3
Andy G is offline Andy G  Australia
Andy G's Avatar
I would guess that the aim of the height is to lift the tweeter to exact seated ear level.
I would have liked to see the mids a bit closer together, but it does depend on the x-o between mids and top.
Also, I guess, if speakers will generally only be listened to while seated, then lobing above speaker level would probably not be an issue.
Old 30th January 2006, 07:13 AM   #4
Im not worried about vertical dispersion. If Im not sitting down and listening I dont really notice much about the sound.
The drivers most likely will be closer together then in the VHT. Ill likely space them right next to one another. Ill most likely leave them in a vertical alignment rather then offsetting the tweeter since I think this is more cosmetically pleasing.
Old 30th January 2006, 09:22 AM   #5
kifeinthesink,
can you post a link to the mentioned D'appolito white paper?
Thx
illusionxx
Old 30th January 2006, 05:22 PM   #6
I only heard a second hand reference to the white paper which is why I'm not sure if it was woofer to tweeter or woofer to woofer. Ill see if I can find it though and Ill let you know.
Old 6th April 2010, 11:08 PM   #7
Artie is offline Artie  United States
Its woofer-to-tweeter spacing, but it might take me some time to find where I referenced that.
The reason I'm reviving this old thread is that I also hope that someone can answer this related question. (Which wasn't clear in what I read elsewhere.) I know that the formula for W-to-T spacing is 13,503.94 / x-over = spacing in inches, but, is that "D" or "R", (radius), in this diagram?
(When using offset tweeters.)
Driver Baffle Spacing vdi_nenna Multi-Way 3 22nd April 2008 11:02 PM
Driver spacing ... ? REALFLEO Multi-Way 2 15th November 2006 07:07 PM
driver spacing memphissound Multi-Way 7 21st August 2006 03:29 PM
3-Way Driver Spacing 69stingray Multi-Way 4 24th June 2005 02:13 AM
is driver spacing important ? busterno1 Multi-Way 12 9th February 2004 06:28 AM
Page generated in 0.10817 seconds (69.24% PHP - 30.76% MySQL) with 11 queries
