Old 29th January 2006, 08:16 PM   #1
jp88 is offline jp88  United States
Default best ht bookshelf for me?
Hello I am looking to build a set of bookshelf speakers (and eventualy a powered sub) for my ht.
I currently have a sony integrated receiver that is rated at 100x5 that came with some crappy cubes and a 50 watt powered sub.
My budget will be pretty limited
One design I have looked at and I am leaning toward at the moment is a design using dayton drivers I saw on parts express
http://www.partsexpress.com/projects...dht/index.html
any constructive input would be apreciated
WHAT
____________
Old 29th January 2006, 11:36 PM   #2
Speakerholic
Cal Weldon's Avatar
Default Re: best ht bookshelf for me?
Does that mean you need help with the building?
That looks like a great place to start. Dayton drivers are known for a good price point and the design is there for you. Two questions:
Will you be using this for music?
Have you heard titanium domes and do you like them?
I guess that's three questions.
One more: Do you have a great big TV and an HD box?
If so, is this going to be big enough for you? Wait, you said the budget is limited. I'd say this is good value.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 29th January 2006, 11:54 PM   #3
Default Re: Re: best ht bookshelf for me?
I could certainly use the help if you are offering
I will be listening to some music, but mostly tv and movies.
I haven't spent any serios time listening to Ti domes, however I did have some aluminum domes in my car and liked them pretty well.
I only have a 27 inch flat screen crt no hd yet. Its hard to afford alot when you have to support 2 kids and a wife.
This is also my first leap into diy home audio. I have done quite a bit of car stereo, and I install a decent amount of ht equipment on yachts as I am a marine electronics technician/installer
WHAT
____________
Old 30th January 2006, 02:45 AM   #4
Speakerholic
Cal Weldon's Avatar
Then with what you've said, that looks fine. And with what you do, you probably know that.
If I'm gonna help with the cabinets, I'll need a plane ticket, a spare bedroom, food, beer and if by chance you can get Jimmy Buffett to drop by, they're be no charge for the labour.
EDIT: If you look at the XO you'll see someone thinks this combo is worth the time.
Old 30th January 2006, 11:14 PM   #5
Spare bedroom check, beer check, food check, I have no money so no go on the plane ticket. oh well I guess I have to do it myself.
On a side note I have actually worked on Jimmy buffets boat, however I don't think I could get him to stop by.
WHAT
____________
Old 30th January 2006, 11:35 PM   #6
Speakerholic
Cal Weldon's Avatar
May I worship the ground on which you walk? He's been my fave for years. I have two sets of speakers named after him.
I noticed my grammar took a slide in that last post: "they're be no charge..."
Must have had one of those previously mentioned beers before typing.
Which ever project you choose. keep us abreast.
Old 31st January 2006, 12:36 AM   #7
Emprov is offline Emprov  United States
I built a set of those and for HT, they're wonderful. Off axis performance isn't the best but Top Gun sounds great through them once you get the placement right. For music, they're a bit harsh but they'll definitely do the trick in a pinch, (I use them for background light jazz over dinner every now and then and they work pretty well for that). Don't plan on using them without a sub for too long though, by themselves, they're just not designed to put out very much low end.
Old 31st January 2006, 02:32 AM   #8
I put together the first cabinet tonight. It will be a little while before I can purchase the drivers and crossover parts but I already had a sheet and a half of .75 mdf laying around so I figured Id go ahead and start putting together cabinets. I will try to post some pics tommorow evening. Also I do have a powered sub already (as crappy as it is I am not sure you could realy call it a sub) but it will have to do for now. It is a 50 watt sony that came with my receiver and speakers. It does have an 8 inch driver though. well thats all for now
WHAT
____________
Old 1st February 2006, 12:33 AM   #9
first cabinet built
4 more cabinets to go I will post some construction pics as I go along.
WHAT
____________
Old 1st February 2006, 04:26 AM   #10
Looks Really Good
My last bookshelf. R-Carpenter Multi-Way 35 28th May 2008 11:53 AM
Ultimate <$200 Bookshelf help spots25 Multi-Way 61 20th September 2007 03:24 AM
Bookshelf Speakers Sammich Multi-Way 5 29th June 2007 08:01 AM
first bookshelf diy mazurek Multi-Way 4 9th November 2005 01:08 AM
Best bookshelf for $100 each? jaybird Multi-Way 2 9th January 2004 11:38 AM
Page generated in 0.17406 seconds (59.73% PHP - 40.27% MySQL) with 11 queries
