I downloaded SW weeks ago but didn't get far with it. Now I've opened my project again and don't know where to start.
All I want is to measure the FR so that I can then design my EQs and LT. Can that be done relatively simply/quickly? If someone could say: "yes it's easy. Just do A, B, C" that would be appreciated. Thanks. |
#2 |
[list=1][*]Use loopback-cable from soundcard output to line-input x (right or left). This is reference channel.[*]Connect your mic to line-input y (left or right, not x
When measuring make sure the left-right maximum and minimum values do not exceed about 32k. Set the volume(s) accordingly. |
#3 |
Thanks, i'll give this a try tomorrow.
My mic is a RS spl meter. Is that output from that amplified? I will try without reference first, because I would have to make up a loop-back cable. |
#4 |
If you get sensible signal levels from your meter, it should be ok. Don't know about the linearity though...
#5 | |
diyAudio Moderator Emeritus
Here are some pointers that might help in future: - After doing a full calibration (follow Wallin or Claudio's website) save your audio mixer settings with Quickmix. This will save you having to reclaibrate every time! Then the next time you fire up SW, just reload the mixer setting from Quickmix, and confirm a few passive components (the reference resisitors on the jig) and you're ready to go. - Create a new SW project specifically for FR measurements and use it as a base when measuring any speaker. You will have all your graph scales set up how you like, and mic calibration file loaded etc. - I usually measure the nearfield, then port response if any, then gated. - Gating. Since I'm not concerned with absolute SPL, I use a measuring distance as close to the driver as possible depending on its diameter to minimise potential room interaction. Then run the impulse response and set the second marker to just before the second pulse (leave the first marker right at the beginning, not at the first pulse). Obviously switch the markers on so gating is activated, then go ahread and meaure the on-axis response. - I highly recommend going through Claudio's website once at least. - IIRC Wallin's site has info about modding the RS SPL meter in case you haven't come accross it. - If you plan on doing this more than a few times in the future, the Wallin Jig will make your life much easier.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#6 |
Thanks Vikash, but maybe you've answered a different question. I'm not that interested in the driver's response by itself. I've already built the speakers so I'm interested in the 'in cabinet in room' response.
For the FR125s I want to see how much baffle step to add at what frequency. It would also be nice to see whether my Heggs have a nice smooth baffle diffraction as intended. And if the FR125 peaks from your measurements are present I'd like to EQ them away and see the result. For the 10" I have incomplete driver data, but was hoping to just measure the in cabinet response to then design the linkwitz transform. I'm pretty clueless on what/how to measure. I was thinking I could just put the mic at my listening position and fire up the pink noise in stereo? |
#7 |
ok, so this is my first meauring attempt.
this is the nearfield response with the mic 150mm in front of the driver. I did no calibration (because I haven't worked that out yet). what does this tell you about my speaker and/or measuring system? Being optimistic I'd say it was pretty smooth, but the 7k peak is quite a bit higher than the other fr125 plots i've seen, and the drop to 11k is deeper. It looks the test gear give up around 13k. i'm using the mic input on a standard dell laptop with the RS sound level meter as mic. The lead from mic to pc is a bit flimsy also. I'm wondering whether I need to buy a mic and preamp from Vikash or a decent usb soundcard, or both. |
#8 |
Nearfield is taken at single digit mm, not tens or hundreds
http://www.claudionegro.com/swacoust...nearfield.html
#9 |
Built-in laptop sound devices are usually rubbish. Even an entry level dedicated USB device will be far better.
#10 |
...that it is an enclosed somewhat small mid-woofer of rather good quality, probably in a closed enclosure, that you need some work in the crossover, and that you have to smooth the curve (smoothing is mostly done in 1/3 of an octave);-)))
| Speaker Workshop | MMadrid | Multi-Way | 0 | 25th June 2006 07:49 AM |
| Speaker Workshop Help | Gavin_mi | Multi-Way | 32 | 28th September 2005 07:22 PM |
| Speaker Workshop: the best and how to use it? | rick57 | Multi-Way | 12 | 13th August 2004 11:12 PM |
| fft (Speaker Workshop) | Dave Jones | Multi-Way | 6 | 28th June 2004 11:49 PM |
| Page generated in 2.84175 seconds (5.43% PHP - 94.57% MySQL) with 11 queries |
