Old 26th January 2006, 03:40 PM   #1
Send a message via MSN to noodle_snacks
Default Passive Line Level High Pass
I need a temporary high pass filter or rumble filter for a subwoofer set at 40hz until i can get something active sorted out.
I had a look at: http://en.wikipedia.org/wiki/High-pass_filter Which seems to give the circuit and the equation, however i have no idea what sort of resistor value to use in order to derive the capacitance required.
Any help as to what sort of resistor value i should be looking at for a line level filter?
Old 26th January 2006, 03:46 PM   #2
It depends entirely on what impedance feeds the filter, and what impedance it in turn feeds. Also, a crude passive filter isn't really steep enough, get a dual-opamp and build an active filter!.
Nigel Goodwin
Old 26th January 2006, 07:16 PM   #3
frugal-phile(tm)
planet10's Avatar
More info
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th January 2006, 12:50 AM   #4
I do indeed intend to build an active filter, i just want a quick and easy passive one until i have the time to do so.
How can i calculate my amplifiers input impedance and preamps output impedance?
Old 27th January 2006, 12:56 AM   #5
pinkmouse's Avatar
There is a thread in SS showing you how to calculate the input impedance.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 27th January 2006, 08:36 AM   #6
a temporary solution is to drastically reduce the
input coupling capacitor value of the sub amplifier.
As prevously stated, won't work that well.
/.sreten.
Old 27th January 2006, 11:19 AM   #7
Thanks for the help, however i found a digital 250 band equaliser plugin for winamp which i will be able to use when i need the high pass filter. The filter can be set for flat response at 39hz and to be 60db down by 35hz.
http://coyote.freeweb.hu/winamp/dsp.cgi
I will probably build a steep opamp filter however since it just so happens the sound source for this little event is a computer running winamp. I have tested the plugin with a spectrogram and it does work effectively at cutting out low bass.
Passive line level x-over - CAN IT BE DONE? hasselbaink Multi-Way 24 21st January 2012 02:16 PM
line level high pass filter rbrockman Analog Line Level 3 13th December 2008 05:21 AM
Need High level, high pass crossover for 250watts Anthrax Multi-Way 0 21st January 2007 03:34 AM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 12:25 AM
Passive line level low and high pass filter help Matttcattt Multi-Way 53 24th February 2004 04:16 PM
Page generated in 0.50654 seconds (19.09% PHP - 80.91% MySQL) with 10 queries
