Dear all,
I have constructed the Ref.Monitors for Scan-Speak drivers (audiocomponents.nl) but I wish to add some extra bass. The sound is a bit on the hard side and I think that some extra bass will smooth the sound a bit. I have three options: 1)Build the Reference Monitor + version from the same site. What do you think about this design. Has anyone made it. Has anyone heard it? 2)Build a subwoofer for each speaker, like the project named “Critical Q Sub” that one can find on the net 3)Build a three way speaker using the drivers that I have (SS9900, SS8546) and buying an extra one for the lows. I have searched for such a loudspeaker but could not find any plans on the net. Finally I have another question. Between options 1 and 2 what are the disadvantages-advantages of each solution. The subwoofers will be active. Thanks George |
#2 |
Rather than looking at adding bass to cover up the problem, I'd be looking at the crossovers for your existing system. A hard sound is usually down to issues in the upper midrange.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
PinkMouse,
You are correct. Rolph from audiocomponents.nl has suggested I change the series resistor for the tweeter from 4.7 Ohms to 5,6 Ohms or change the parallel resistor to 15Ohms. I will be doing these modifications soon, but I was wondering if a subwoofer would give me better results in medium listenings levels. I dont like my music played very loud. Thanks |
#4 |
Hi
So did you do the mods and if so which did you do. I am looking at building a set of the Ref Monitors and am interested in any info I can find. Cheers Geoff |
#5 |
I have not made the modifications. I have a problem with the exterior finishing of my cabinets.
| Scan-Speak 3-way design (Ekta Grande modified) | pjpoes | Multi-Way | 12 | 6th July 2009 09:29 AM |
| Closed box design:Scan Speak monitor | Jonasa | Multi-Way | 74 | 13th May 2007 08:17 PM |
| Design for Scan Speak Revelator + 8545k | TEK | Multi-Way | 17 | 29th April 2005 03:35 AM |
| Scan-speak M1 (again..) | macgyver | Multi-Way | 0 | 31st October 2002 08:39 AM |
| Page generated in 0.07595 seconds (72.76% PHP - 27.24% MySQL) with 10 queries |
