Old 25th January 2006, 03:42 AM   #1
edjosh23's Avatar
Default Bass reflex used as active BSC?
I was wondering if a rear firing port could be used as active bsc. If the box is designed a bit larger than it should be, there would be a sight hump at the tuning frequency. If there is a 3db hump coming from the back of the enclosure, could this make up for a baffle loss?
Thanks,
Josh
Old 25th January 2006, 04:06 AM   #2
Send a message via AIM to joe carrow
Keep in mind that bass (within the range of what comes from a port) is not directional enough to care where on the enclosure it is coming from. The port can be pointing down, left, right, or behind or on top- and it will really only care about its point in space and how many fractions of a wavelength it is from nearby boundaries.
It might not be proper baffle step compensation, but the end result of the baffle step is quiet bass (with respect to the rest of the system), so you're definitely able to make it less of a problem by designing an enclosure with more pronounced bass.
You'll need to pay attention to what frequency your baffle step starts- cabinet width should tell you this, and how pronounced the effect is before room gain comes into play- determined by room dimensions.
Bottom line- I'd recommend an alignment with a broad raise of level starting at a frequency at something that's probably well above the tuning frequency, and without a very sharp peak anywhere near resonance.
Old 25th January 2006, 05:59 AM   #3
owdi is offline owdi  United States
owdi's Avatar
Not a good idea. The peak from tuning high in a big box is much narrower than the gradual (about 2db/octave) baffle step.
A better solution is a second driver directly opposite the front driver. No baffle step compensation to worry about, and the drivers will cancel out vibrations in your enclosure.
Dan
css bass reflex paulfk Full Range 7 8th March 2009 11:25 AM
Bass reflex box resonance costin Subwoofers 15 1st May 2006 07:12 PM
Need Comments on FR Bass Reflex blip1882 Full Range 11 28th September 2005 05:48 AM
Bass Reflex Guss Multi-Way 1 15th December 2003 02:33 AM
bass reflex? GAK Multi-Way 2 23rd October 2001 03:04 AM
Page generated in 0.08996 seconds (61.35% PHP - 38.65% MySQL) with 10 queries
