Driver & Port Location
Old 24th January 2006, 01:13 PM   #1
gpsmithii is offline gpsmithii  United States
Default Driver & Port Location
Im building a pair of studio monitor type systems. The enclosure is of bass reflex type. I would like to place the ducts on the front of the enclosure. The woofer is 15 and the tweeter is a horn whose lenses measures 5.1/4x5.3/8. I would like to put the ducts ( 2 X 4 X 7.71) on the front. The information I have reviewed says that there should be 3 4 between any interior surface and the ducts. It also states that the ducts should be the same distance from the woofer as minimums. I could place the ducts in the same plain as the horn. Is there any acoustical reason to not do this? I know the other option is to place them on the rear panel. What distance would you recommend between the woofer and tweeter?
Thanks in advance for your suggestions and feedback.
Old 24th January 2006, 05:26 PM   #2
the woofer and tweeter should be fairly close and vertical.
The tweeter can be offset to the side somewhat.
The port beside the tweeter (or ports either side) should be fine.
Driver & Port LocationHide this!Advertise here!
MJK worksheets vs port location johngalt47 Multi-Way 3 9th March 2009 12:35 PM
Port Location ERICSPEEd Multi-Way 4 3rd December 2008 10:50 AM
MLTL reverse driver/port location thinkbad Full Range 1 4th April 2006 08:57 AM
Port location andy2 Multi-Way 1 17th October 2005 10:20 PM
port location? joe_daddy Car Audio 4 18th August 2004 01:38 PM
