Chasing dipole bass quality....
The Big Question.... Could something like a single 12" XLS or a single 12" RSS be satisfactorily operated as a low-mid-bass driver in a dipole? Say something like from 80 - 300 hz. If so (drum roll please) what would the neccessary path length be in order to achieve a satisfactory result? What could be expected in the way of efficency? Could a satifactory SPL be reached in the 80 to 100 Hz range before the driver ran out of excursion? These are all very troubling questions Im not lazy - I'm just stoopid - Isn't there a program available for modeling these parameters?????? |
#2 |
http://www.diyaudio.com/forums/showt...473#post825473
Thorsten Loesch´s tool will help to determine max SPL too.
www.dipolplus.de |
#3 |
No takers?
Okay Okay,,,I'll come up with some math from SL's webiste, maybee that'll help. Dipole bass uses up excusion big time...but what if you don't even try to go low...maybee just to 80 or 100 hertz.... C'mon I need some insight ! There is a path length that defines what the response will be..what would the path length need to be? Could one "big excusion" woofer provide the SPL if all it had to do was deliver 80/100hz and above?????? (snort) |
#4 |
Hi there
I am not sure about the 12" RSS, but the 12" XLS is definately not clean enough in it's uppper registers to be used so high up. I would also be looking at the Ascendant Audio Assassin 12 as a possible solution. Even the Assassin 10 could be good enough. Enjoy, Deon
Reality is not digital, an on-off state, but analog. Terry Pratchett - Moving Pictures |
#5 | |
Banned
The Sd and xmax of your drivers are fixed. Path length and SPL are directly related variables: http://www.linkwitzlab.com/spl_max1.xls
When you determine what will Quote:
Cheers, AJ p.s. don't forget to add 6db for half-space |
| Any old hippies or rock brains out there? | rick57 | Music | 41 | 24th January 2011 09:59 PM |
| Collective knowledge…let’s pool our brains | Eggzy | Parts | 16 | 24th March 2006 11:00 PM |
| reclockers UNITE! Valpey-fisher extreme XO may be available... | drlazybones | Swap Meet | 19 | 18th November 2005 04:18 PM |
| FS: drum brains | salakokk | Swap Meet | 0 | 10th April 2005 01:16 PM |
| Buffalo brains | macmeech | Introductions | 1 | 15th June 2004 06:03 PM |
| Page generated in 0.07770 seconds (75.66% PHP - 24.34% MySQL) with 10 queries |
