Old 23rd January 2006, 10:27 AM   #1
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default Centre channel configuration (Extremis & North D28)
I started building a sideways MTM using Extremis 6.8’s and a North D28. But I’ve become increasingly worried about the correctness of this configuration for a centre channel (what with lobing ‘n all). I concede that I should have built at least a 3-way
. T
WMW
But I have just about enough space to squeeze in a Morel MDM55 2” mid, which I’m inclined to do.
Is this a good solution?
Any opinions on this mid?
What crossover frequencies would suit this design?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 23rd January 2006, 01:47 PM   #2
http://www.partsexpress.com/pe/showd...number=279-274
may interest you.
/sreten.
Old 23rd January 2006, 04:35 PM   #3
In my opinion a W-T/M-W is always better than a M-T-M. A dome midrange goes safely only to like ~500Hz, while I think it would be better to get the x-over frequency a bit lower than that. If you've already built the enclosures and can't fit a bigger midrange (4"-5") you can go with a dome. The MDM-55 should be a good choice.
Of cource you should always keep your center as similar as possible as your mains.
Old 24th January 2006, 06:44 AM   #4
Shaun's Avatar
sreten
I have looked at that part, and it is indeed interesting, but I have not found any info indicating that it might match the performance of the configuration I'm presently considering.
Landroval
My floorstanders are TMM's and the surrounds are TM's (D28's and Extremiis). I intend matching them by FR for this project. Next time, I'll definitely have a mid for at least the front and centre speakers.
Shaun Onverwacht
Old 24th January 2006, 01:05 PM   #5
Send a message via AIM to ssabripo
Originally posted by Shaun
[B]sreten
Shaun,
I have the Swan 3C center, which uses that part (see below)....it is definitely a very capable combo, and very musical. BUT, it is NOT in the same caliber as the Seas or Morel offerings, or even the Vifa ones. IT IS, however, a phenomenal offering for the price!
O/B Centre Channel Cloth Ears Full Range 7 15th January 2009 03:25 PM
How to setup using Extremis 4 ohm driver in 2-way configuration for car audio kippo Multi-Way 1 6th August 2008 11:07 AM
Phantom centre channel with centre channel lol Toast_Master Multi-Way 5 5th December 2006 03:54 AM
centre channel Please Help Pat.P Multi-Way 3 27th August 2005 06:21 PM
Centre Channel Design griff Multi-Way 10 29th January 2002 01:01 AM
Page generated in 0.09403 seconds (83.50% PHP - 16.50% MySQL) with 11 queries
