Old 25th January 2006, 08:02 PM   #31
pinkmouse's Avatar
Makes sense to me, but then I understand the principle.
As for noise, I have done this kind of thing before, and run up to about 200Hz, but that was with 10" drivers. It is probably worth just fixing one to a bit of sheet material and having a listen with a signal generator.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 25th January 2006, 08:13 PM   #32
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
200hz isn't so bad... and these blatently won't be close in pure quality terms to my current mid/basses so I don't want to make them play too high! Got to make a trade-off between overall headroom/power distribution and the cheap drivers spoiling the gentle music!
After work and the gym and cooking it's always too late to do anything on a week day, but I'm gonna try to get some work on this done on Saturday!
Old 30th January 2006, 08:29 AM   #33
SimontY's Avatar
Ok, if anyone's interested (or not ) it's time for an update, a picture update.
Old 30th January 2006, 08:32 AM   #34
SimontY's Avatar
My friend modelled the cabinets in Autocad.
Here's some MDF, including the front baffle, prior to cutting. B&Q were happy to do all my straight cutting for free (well, the friendly old chap working the circular saw was, anyway).
Old 30th January 2006, 08:36 AM   #35
SimontY's Avatar
Showing just the internal front drivers resting against the baffle. You can see the port will be a slot.
Old 30th January 2006, 08:38 AM   #36
SimontY's Avatar
I am having to trim the driver chassis on the internal drivers to fit inside the extremely narrow boxes. I will also have to route a portion off the side panels to let them sit correctly against the front and rear baffles.
Old 30th January 2006, 08:42 AM   #37
SimontY's Avatar
For this prototype I'm not sealing the drivers with anything that costs me money, although, frankly I'm not sure this masking tape on frame and cutout will be a good enough seal...what is a good enough seal, must it be perfect?
Old 30th January 2006, 08:46 AM   #38
SimontY's Avatar
And here is what one baffle looks like:
It really is rather heavy!!
Old 30th January 2006, 08:51 AM   #39
pinkmouse's Avatar
Looking good Simon!
I use foam draft proofing strip for sealing drivers, cheap, and works well. You could use blutack or similar for a test box.
Al
Old 30th January 2006, 09:18 AM   #40
SimontY's Avatar
Looking good Simon!
Good morning and thanks PM, that is a good tip.
Does this wiring look correct to you? I find it hard to get my head around, but I think this config gives 8 ohms, which is the best I can get with 8 drivers I think.
Behringer crossover audiophile quality, bi/tri amping stereo speakers? cirrus18 Multi-Way 25 29th December 2008 12:55 PM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
Two LM3875's for bi-amping OB speakers inrank Chip Amps 5 5th May 2006 08:33 AM
Page generated in 0.10599 seconds (74.10% PHP - 25.90% MySQL) with 11 queries
