Old 23rd January 2006, 06:15 AM   #1
Send a message via MSN to noodle_snacks
Default Reverse mounting drivers
What is the best way to mount drivers with the magnet facing outwards in order to get a good air seal at the edges, and have a secure connection for the driver to the enclosure?
Old 23rd January 2006, 07:32 AM   #2
dnsey is offline dnsey  United Kingdom
Er... the same as mounting them the 'right way round', but from the other side of the baffle?
Old 23rd January 2006, 09:51 AM   #3
the speakers i am looking at have a steel lip, screwing them from that way round wouldn't get a very good air seal at all, i am looking for suggestions to prevent air noises etc
Old 23rd January 2006, 10:15 AM   #4
pinkmouse's Avatar
Cut cork tiles to fit in the gap between the surround and the metal rim. Depending on the depth, you may need one or two layers.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 24th January 2006, 02:24 AM   #5
myhrrhleine's Avatar
A small bead of silicon caulking all the way around makes a great seal.
Old 24th January 2006, 05:36 AM   #6
would the chalking hurt the driver whilst drying?, or can it be put down thinly, and left to dry before the driver is put in place?
Old 24th January 2006, 05:45 AM   #7
May I ask why do you want to reverse mount a driver anyway?
Old 25th January 2006, 02:11 AM   #8
The driver will be placed in a horn and the only way to screw it in is from the rear. Sometimes people put drivers in a push pull configuration to cancel out some types of distortion as well.
Need Help Mounting Drivers aggielaw Multi-Way 1 10th February 2005 02:08 AM
Mounting loudspeaker drivers into cabinets (Decoupling) Puggie Multi-Way 4 27th October 2004 03:04 PM
Importance of flush mounting drivers RyanC Multi-Way 16 27th May 2004 09:10 PM
Flexible mounting of drivers? Jonathan Bright Multi-Way 13 19th April 2004 11:02 PM
Mounting Drivers GeniX Multi-Way 4 20th September 2002 05:24 PM
Page generated in 0.08922 seconds (76.34% PHP - 23.66% MySQL) with 10 queries
