Old 22nd January 2006, 11:23 PM   #1
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
Default dynaudio tweeter match and enclosure
I got these drivers 4cheap. I might resell them or use them for my first speaker project. Could anybody recommend a tweeter for a 2-way? I would like a simple xo(first project)
I realize their q is not suitable for transmission line. Am i right? (i would like to go tl)
Bas
Old 23rd January 2006, 12:01 AM   #2
beamnet's Avatar
grr... i forgot to tell you i have 24w100 drivers. I just read the martin king for dummies thing again... these would form a tough speaker to go tl with...
Old 23rd January 2006, 06:07 AM   #3
Tomac is offline Tomac  Croatia
post here the TS parameters of the driver
Old 23rd January 2006, 10:33 AM   #4
beamnet's Avatar
here you go!
Old 23rd January 2006, 11:21 AM   #5
David Gatti's Avatar
I'd be going for something like the Morel MDT33 (or one of it's cheaper cousins), crossing at about 2.5kHz. Very easy to crossover, and very high power handling.
http://www.morelhifi.com/products/pdf/mdt%2033.pdf
Old 23rd January 2006, 11:40 AM   #6
beamnet's Avatar
I DEFINITELY would have to go for a cheaper driver!
I might have these fancy dynaudio drivers, but as i said, 4 cheap! I have a maximum budget of about 50e for them! ($65)
Bas
Old 23rd January 2006, 11:55 AM   #7
using a very expensive 10" bass driver in a 2 way is asking for trouble.
There is no simple way of doing it, you need a 3-way IMO.
You are probably best selling the drivers if you can't afford
to build the rest of a system to match their capabilities.
/sreten.
Old 23rd January 2006, 11:59 AM   #8
beamnet's Avatar
it's not 10 inch, it's 100mm voice coil
in fact it's conde diameter is 173 mm
The datasheet sais it is able to be used in a 2-way...
Bas
Old 23rd January 2006, 12:11 PM   #9
SEAS 27 TFDC
cheers,
Inertial
Old 23rd January 2006, 12:18 PM   #10
beamnet's Avatar
I like the price range of the seas, but that driver does not turn up any google hit neither can i find it at speaker suppliers..
How do I match a woofer and tweeter? chasingame Multi-Way 3 6th August 2009 07:35 PM
What tweeter to use to match the C-Quenze? trusound Multi-Way 2 23rd November 2005 01:28 PM
Woofer/Tweeter match Mjr7531 Multi-Way 5 5th April 2005 11:47 PM
cheapish tweeter to match with PHL 1360 dunderchief Multi-Way 1 14th November 2004 10:51 PM
tweeter tweak/match paulj Multi-Way 2 21st May 2004 10:38 PM
Page generated in 0.10526 seconds (77.51% PHP - 22.49% MySQL) with 11 queries
