Old 20th January 2006, 11:10 AM   #1
beppe61 is offline beppe61  Italy
Default Suggestion for the best cone for 150-3000 Hz range.
Dear Sirs,
I am looking for suggestion about very good cone drivers able to cope with the 50-3000 Hz range.
This should be the center of a future 3 ways design.
I live in Italy so the brand should be available worldwide.
Thank you so much.
Kind regards,
beppe
Old 20th January 2006, 12:14 PM   #2
Scottmoose's Avatar
150Hz-circa 3KHz? Vifa P13W. Doesn't even need a notch-filter.
Cheers
Scott
Old 20th January 2006, 12:25 PM   #3
keyser is offline keyser  Netherlands
I've heard very good things about the peerless HDS excl. line, and especially the 152. Should work well in the band you intend to use it.
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche
Cardioid-like + Waveguide 2-way
Old 20th January 2006, 12:54 PM   #4
Default Re: Re: Suggestion for the best cone for 150-3000 Hz range.
Originally posted by beppe61
Please excuse me: the range should be
from 150 - 3000 Hz actually !
Thank you sincerely for the excellent suggestions.
Kind regards,
beppe
Old 20th January 2006, 05:08 PM   #5
filgor is offline filgor  Australia
Both the previously suggested P13WH and the Peerless HDS 5" (152) are in the same performance and price range. And both are great for 150-3000Hz. I'd choose whichever one you prefer the look of!
Old 20th January 2006, 06:19 PM   #6
Dear Sir,
thank you very much for your kind and helpful reply.
I have just one doubt.
I heard that cone mids at frequency of the order of 3000 Hz tend to become directive (bad dispersion).
Could it be a problem ?
Thank you very much.
Kind regards,
beppe
Old 20th January 2006, 08:42 PM   #7
you may like the SPH-102KEP
crazy good extension to 8 khz, very small breakup around 10khz, and cheap (50 euros), also it is a 4 inches so you don't have any directivity problem at 3khz, and i believe monacor is widely available anywhere in europa
if the bass extension is not sufficient, the SPH-135KEP do have almost the same extension, and go much lower, has better xmax, but is one inch bigger and costs a little more
i have the SPH-135KEP and the 165KEP. Both are very good drivers IMO
Old 20th January 2006, 09:56 PM   #8
simon5 is offline simon5  Canada
Creative Sound WR125S
http://www.creativesound.ca/pdf/WR125S.PDF
Creative Sound FR125S
DIYaudio for President !
Old 20th January 2006, 10:04 PM   #9
serengetiplains's Avatar
Try the Audio Technology (Skaaning) 4" Flex Unit. Expensive, but look at that response curve!
Tom
Old 20th January 2006, 10:18 PM   #10
owdi is offline owdi  United States
owdi's Avatar
Dear Sir,
Kind regards,
beppe
Directivity can be a good thing. In general you want to match the average directivity of your woofer to the tweeter.
My personal favorite of the month is the Vifa XG18. It's a 7" speaker that is -3db 30 degrees off axis at 3000hz, and -1db 30 degrees off axis at 1500hz. Since you're crossing two octaves above fs you don't need to compensate for the impedance peak. Unless you use a very wide baffle you will need baffle step compensation.
Dan
Dan
full range without whizzer cone NED 209 Full Range 31 13th January 2008 12:04 AM
Freq range for Apex Jr 3" M&K twin cone? Brisso57 Multi-Way 0 4th September 2007 11:05 AM
Seas 11F-lGWD full range with whizzer cone capslock Full Range 1 7th October 2005 06:26 AM
Page generated in 0.09524 seconds (84.66% PHP - 15.34% MySQL) with 11 queries
