I am looking to change some tweeter drives on a speaker kit I made a while back. Is it as easy as just getting a better drive's and replacing them, or will some drives only really work with a certain cross over box design and bass/mid unit. What I am really asking is their a bit more science to the whole thing then just getting new drives.
At the moment I have Treble: Scan-speak D2905-9700 soft dome tweeter 90dB ~ 6 ohm ~ 104mm o/dia ~ 44mm deep ~ 28mm vc ~ 225w power ~ 500Hz Fs ~2-30kHz range Looking at R2904-700000 Ring Radiator Tweeter 94.5dB ~ 4 ohm ~ 104mm o/dia ~ 31mm deep ~ 25mm vc ~ 150w power ~ 520Hz Fs ~ 2-40kHz range I know it would be a big step up but have been offered them at half the price of new cost, costing about the same as the drives I already have. Thanks |
#2 |
diyAudio Moderator Emeritus
You will need to change the xover too. There are times when you can find a drop-in replacement (will work fine with current xover) but most times upgrading drivers will require upgrading xovers if you're doing it properly.
Yes, there is more science to it. And often more black magic to it as well
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#3 |
| CD controller kits - any do 2 drives ? | mobyd | Swap Meet | 0 | 3rd November 2008 08:16 AM |
| Alternator/Drives Question | richie00boy | Everything Else | 7 | 28th June 2008 05:51 PM |
| OTL SET 300B drives F4????? | ro9397 | Pass Labs | 3 | 19th October 2007 02:42 AM |
| need advice about cd drives | 56oval | Digital Source | 0 | 14th July 2006 12:31 AM |
| Beyma drives, wich one of these? | -_nando-_ | Multi-Way | 12 | 29th June 2006 05:17 PM |
| Page generated in 0.08050 seconds (72.17% PHP - 27.83% MySQL) with 10 queries |
