Old 19th January 2006, 05:25 PM   #1
Default Plastic mid/tweeter enclosures?
Comments on molded plastic enclosures such as the one below appreciated. Should they be used. If so why do commercial setups not use them.
Old 19th January 2006, 07:44 PM   #2
Long ago, Vandersteen did; it was a cone that was designed to match a Vifa? Seas? midrange. The mid and or tweet should have their own back sealed boxes, to prevent the woofer-induced cabinet pressure from modulating them. If the volume is correct for the LF end of the mid, there is nothing wrong with using the plastic; I'd add a damping (water based only) glop, and felt the inside to reduce vibration and reflection. From what I can see from the picture, they would be suitbable for a fairly high bass/mid crossover freq and a relatively small mid.
Old 19th January 2006, 08:08 PM   #3
Default vifa/seas/audax
The picture is a Vifa cover. Solen carries covers for Vifa, Seas and Audax. I agree with your point about preventing modulation but would like to know why most commerical cabinets do not use this type of enclosure.
Old 19th January 2006, 09:07 PM   #4
AJinFLA is offline AJinFLA  United States
Banned
How do you know that most commercial speakers with midranges don't use a back cup? I honestly don't know what the insides of most boxes look like, because I really wouldn't care. Here's at least one:
http://manuals.harman.com/INF/HOM/Te...%2050%20ts.pdf
part# 18. I posted this because I knew Harman had specs on their site readily available. I suspect most would have something similar for their mids, but who knows?
AJ
Old 19th January 2006, 09:08 PM   #5
For mids, the enclosure volume is critical, as it determines the driver LF response (without crossover). This will be a crossover pole, and it's pretty convenient to add a wood/mdf box in a wood/mdf cabinet that is exactly the right size to get that pole placed at the right frequency. I used slanted back boxes for the mid.
Many tweeters are self enclosed.
Old 19th January 2006, 11:11 PM   #6
influx is offline influx  United States
Originally posted by Curmudgeon
Long ago, Vandersteen did......
Not as uncommon as you would think! This is mid driver from a Scott speaker circa 1968. Scott used this driver config w/enclosure in at least 5 models that I know of. I'm restoring a pair of S-11D's with a damaged mid cone and trying to find a replacement pair.
Driver replacement, just the FAQ's mam (ahem, men:-)
Plastic TLs Geoff H Full Range 24 12th November 2006 02:27 AM
fullaranger as midrange, and plastic enclosures lufbramatt Multi-Way 24 17th October 2005 07:16 AM
Midrange and tweeter enclosures murat Multi-Way 16 3rd February 2005 08:32 PM
tube tweeter enclosures? jazzbearz Multi-Way 6 19th January 2005 09:27 PM
Page generated in 0.32663 seconds (-45.58% PHP - 145.58% MySQL) with 11 queries
