tl, tl with other drivers or no tl at all? - Page 2 - diyAudio
Old 19th January 2006, 06:50 PM   #11
joensd is offline joensd  Germany
If want something "good for the money" get yourself the Gradient W160AL8 driver. I built a TL with it and like it very much.
Doesn´t work as a fullranger though as "advertised" by Klang+Ton.
I mated it with a Tangband but would use a Veravox3 or tweeter if I should modify it in the future.
But see here:
Gradient TL
Hifi-Selbstbau projects
jens
Old 20th January 2006, 07:11 AM   #12
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
Pfff...
choosing is hard!
Just another q
I van get my hands on a pair of dynaudio 17w75EXT woofers 4 cheap
are they suitable for tl?
I hear great things about these drivers
Bas
Old 20th January 2006, 07:17 AM   #13
beamnet's Avatar
Maybe a good point to resumate what we're at
There are some good driver combo's suggested.
The tl-calculations are no problem. I can design my speaker.
I am, hower, a nono on the xo part.
i REALLY like the 1 cap xo (if you made your own am, paistakingly choosing as little components in the signal path, you DONT want 50 components in your xo!)
I am currently bidding on a viva xt25 tweeter, ad that seems a good one 4 sure. And i like the looks!
Can anybody tell me more how to handele the xo part?
Bas
(i don't mind having to build a few prototypes bfore the actual line length is decided)
Old 20th January 2006, 02:57 PM   #14
Tomac is offline Tomac  Croatia
Zaph measured it so check his web www.zaphaudio.com
1st order crossover depends on drivers you choose. It is definitely possible to make a 1st order on XT25, question is will that be best xo for that tweeter? Distortion is pretty high below 1kHz. Hmmm. I cannot swear that a 4.7uF cap will be enough to get best of it.
You should ask someone who worked with it. If i have to judge by numbers I would stay away from XT25 if first order is a must.
Seas 27TDFC seems much better for that purpose. It is even cheaper. Also a noferro version (27TDC) seems nice
Old 20th January 2006, 03:10 PM   #15
beamnet's Avatar
if i wouls want to look for a first order filtered tl. what should i look for in tweeter and bass speaker. I can do my own research, but i would have to know what to look for.
For that vifa tweeter: currently, the bid is $1. I think that's quite a bit of mass in the equation. Could it be mated with that peerless driver mentioned before (the HDS - 134 / 850488)
I like the peerless, because it is like the one in the flatline i mentioned at the strat of this topic.
This might meand a bit more components in the crossover, but i the component count stays below, say, 5 or so, that's okay with me, but i sometimes see xo's with 10+ in it.
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
Copyright ©1999-2017 diyAudio
