Old 24th January 2006, 08:31 PM   #31
frugal-phile(tm)
planet10's Avatar
Originally posted by chops
I just prefer a loudspeaker that is simple and straight forward in design.
Don't get me wrong -- that is my preference too... the amp of my dreams (still working towards it, will have 4 - 8 W so efficiency is important to me, and the simpler the path before the amp, the better.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th January 2006, 09:12 PM   #32
Scottmoose's Avatar
Simple has its benefits. I'm building a Son of Zen, which probably says it all, though I wouldn't want to try using it for every speaker or application. In answer to your question regarding integration, it depends on the drivers respective efficiencies, roll-off characteristics, optimum crossover points and a host of other factors all of which need to be considered. Hense something like the 15" Hawthorn might be a good bet as it removes that worry. As a bonus, like the legendary Tannoy Dual Concentric drivers, it's a co-ax, so imaging, time-alignment and phase should all be first rate.
That SI amp. It'll need tweaking as they cut out pretty quickly under 100Hz as I recall. I think TNT-Audio have a guide to modifying these things, and Hifi World ran an article a few months back. I'm not a fan of either of these in all honesty, but in this case it might be useful.
Best
Scott
Old 24th January 2006, 10:25 PM   #33
frugal-phile(tm)
planet10's Avatar
The most comprehensive guides are actually right here on this forum.
dave
Old 25th January 2006, 12:09 AM   #34
chops is offline chops  United States
chops's Avatar
Also, I would just like to add that the SI amp seems to be quite capable all the way down to at least 20Hz, not 100Hz.
The reason I say this is because I just installed a pair of Aura Pro Bass Shakers on the siedes of my couch and I'm powering them with that SI amp. (not very loud of course, but it doesn't need to be either)
I played a couple pipe organ CD's that I know very well and that have true bass down to 16Hz, and I could definately feel all of it.
Now we're going to watch a movie with them.
Charles
Old 25th January 2006, 07:33 AM   #35
Scottmoose's Avatar
Originally posted by planet10
The most comprehensive guides are actually right here on this forum. dave
I believe it. Proves how much attention I pay to amps doesn't it?
If that thing can now hit 20Hz, then they must have changed it. So much the better. it saves getting the soldering iron out and removing a resistor.
Cheers
Scott
Old 25th January 2006, 08:39 AM   #36
frugal-phile(tm)
planet10's Avatar
Even without mods it can hit 20 Hz, but not flat to 20. The input caps are too small. Chops is using it bass only so has no reference to the higher frequencies.
dave
Old 25th January 2006, 12:15 PM   #37
chops's Avatar
dave
Speaking of which, we watched "The Italian Job" last night with the SI amp powering those bass shakers. It actually does quite an impressive job. We really like the part towards the end when they blasted that armored truck through the street.
With the sub pounding away and those shakers "shaking" my hiney, it was pretty neat.
Anyway, I think I'm starting to vear off topic. OOPS!
Charles
Time To Try Open Baffle Mutley666 Multi-Way 40 1st March 2006 08:50 AM
line array open baffle spkerguy Multi-Way 5 6th January 2004 08:42 AM
Uber cheap open baffle line arrays -- almost done ryoshu Multi-Way 5 1st July 2003 11:31 PM
Open baffle drivers configuration: time to ask the experts Peter Daniel Multi-Way 28 31st October 2002 05:54 PM
Page generated in 0.10647 seconds (77.88% PHP - 22.12% MySQL) with 11 queries
