Well I have a pair of Sansui Sp-1500's that I have restored. I accidentally blew all four 1 inch metal dome tweeters one day while working under my desk. The amp was on and up half way and I accidentlly unplugged the source.. needless to say it fried all four coils.
I can't seem to find a set anywhere, I have checked ebay but without any luck. The tweeter domes themselves are easy to replace or recoil, but I have no idea where I would get replacment diaphragms, or if the domes can actually be recoiled. They are 16 ohms each, run in paralell to equal 8 ohms. I was thinking about getting four of these http://www.partsexpress.com/pe/showd...number=279-082 and wiring two in series in each cabinet to make 8 ohms. I was wondering what your sugguestions are and what you think of this particular tweeter. Also, is there a way to be able to use 8 ohm tweeters in this? It would make tweeter selection a little easier, as I might be able to get some with replaceable diaphragms. when I get replacment tweeters, especially if their originals, I am going to put inline fuses with them to prevent further mishaps!! any reccomendations on what type of fuse to use also? |
#2 |
any ideas
#3 |
Combination of two 8ohm drivers will give either 16 or 4 ohms , depends on way you wire them (but I guess you knew that). It is not a problem ,them being a different impendance, but this requires changing some values in crossover. That driver you gave link for seems ok and honestly I don't think these speakers deserve better than that. If the faceplate of driver and baffle cutout fit together I can't see a reason not to go for it. I guess the highpass filter is set high so any proper sounding tweeter would fit in. You only have to take care of sensitivity, don't know what was the sensitivity of original tweeters.
#4 |
thats the one thing I was worried about, these speakers are very efficient. I believe 99db is what the old ad's say.
Maybe thats why they had two tweeters in each cab, to make it more efficient? as long as they will sound like they did before I'll be happy, as they sound wonderful |
#5 |
8 ohm tweeters would be difficult use without modifications to the crossover. In low efficiency speakers it would be possible to pad the 8 ohm combo back to an eight ohm pair but in your case I don't think this a sensible proposition. Your proposition for the Peerless tweeters appears entirely sensible. At that price opinions on the sound quality of the tweeter are pointless. But I'd suggest they probably will be better than the old tweeters. Fuses on tweeters I haven't seen for a long time. I suggest you investigate Polyswitches. If the Peerless units use ferrofluid they will be very robust. |
#6 |
alright, its only $35 so its not completly breaking the budget. Besides, if I come across an original pair on ebay later on I can grab them. Do you think sensativity will be an issue?
just a thought, but I can't seem to find many 4 ohm tweeters out there. Are there any others you can think of ? |
#7 | |
#8 |
LOL ok. As long as I keep my 99db sensativity I'll be fine, as I like to use my lower wattage amps on these (because they sound so good!)
I am looking for a nice Marantz 2235b to power them so I want to keep the effiency. |
#9 |
#10 |
the two Peerless tweeters in series will pan out at 93dB/W. in a 3-way speaker a 93dB/W tweeter would be used with a 93dB/W midrange and a 99dB/W bass unit. I'm presuming this is where your 99dB/W has come from. A speaker with flat response and a genuine 99dB/W midband sensitivity would need a 105dB/W bass unit. I'm presuming this it not the case for your speakers. |
| tweeters | tonysherwin | Swap Meet | 0 | 22nd April 2008 12:16 PM |
| ESS AMT 1a tweeters | BrettP | Swap Meet | 0 | 21st May 2006 06:59 AM |
| FS: Phy-Hp tweeters | Sjef | Swap Meet | 2 | 29th October 2004 08:33 PM |
| tweeters....... | ermes | Multi-Way | 1 | 17th May 2004 02:00 PM |
| Tweeters | Vivek | Multi-Way | 13 | 23rd October 2001 10:06 AM |
| Page generated in 0.11877 seconds (80.93% PHP - 19.07% MySQL) with 10 queries |
