Old 18th January 2006, 04:43 PM   #1
Puggie is offline Puggie  United Kingdom
Default Multi-cabinet loudspeakers, how do you isolate the seperate cabinets?
My Current project is a 2 way design using Bandor-50s for the top end and Seas L22 for the bass. I am so impressed with the sound of the Bandors on thir own that instead of building both drivers into one cabinet, I have decided to split the box into 2 seperate cabinets.
So the Bandor will sit in about 1.5l each and the boxes will be around 5.5" high and wide, and about 8" deep. this will sit on top of the Seas cabinet which will be built to about 10-12l I think, 5.5" wide again, 9" deep and as high as need be to get the bandors at ear level.
So I have 2 boxes and the bandor needs to sit on top of the Seas, how do I isolate the two boxes, spikes, rubber feet etc, what does anyone suggest.
the reasons for the 2 box method are:
I can stand mount just the Bandors and use a seperate sub if I want at a later date,
I can easily move the Bandor on top of the seas to time align the drivers.
I want to!
So what sould be a suitable way of mounting one box on the other?
thanks
Old 18th January 2006, 04:59 PM   #2
Speakerholic
Cal Weldon's Avatar
There are probably a hundred ways of doing it but if you put it on any sort of pedestal or feet, aren't you separating the drivers more than you want? Doesn't that also interupt the continuous baffle effect?
I think you might want to get a piece of the rubbery material that is used for placemats on boats to stop the dishes from sliding. I can't remeber the name but it's become quite popular as of late. You can often get it at the hardware store. It would prevent the upper box from moving once you have them time aligned.
I have used that stuff and also velcro to hold speakers in place.
Just a thought.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 18th January 2006, 05:21 PM   #3
http://www.t-linespeakers.org/projects/rune/index.html
you may find useful.
/sreten.
Old 18th January 2006, 05:37 PM   #4
pinkmouse's Avatar
Also sold as router mat, to stop your work slipping whilst you attack it with power tools. It's what I used for my system.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 18th January 2006, 10:25 PM   #5
David Gatti's Avatar
I just use a piece of felt PVA glued to the base of the satellite.
Use Corian for loudspeakers cabinet ... Domenico Multi-Way 22 4th September 2003 05:54 AM
How to isolate I2C Popolvár Digital Source 3 11th June 2003 03:54 PM
To isolate, or not cm961 Chip Amps 2 22nd May 2003 07:44 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Page generated in 0.09525 seconds (75.59% PHP - 24.41% MySQL) with 11 queries
