Hi all,
After years of hard meditation, failures, retries, despair, totally destroyed loudspeaker drivers and even some success I decided to make webpages about the new capacitive motional feedback method. Pages can be found here: www.servospeaker.com Pages are not too pretty (web design is not exatly my strong part) Warning: This system is potentially dangerous to your drivers, and maybe even yourself as there are some high-voltage parts involved (no current needed though) so take care of yourself (and your drivers)... Comments are welcome! |
#2 |
Nice !!!
The coolest part is that it is a very straightforward construction of a linear sensor. This is an important point if a technology shall be applied in large scale production. BTW: How much did the international patent application cost you ? Regards harles |
#3 | |
#4 |
Banned
This is very interesting Nuuti. Thank you for sharing all your hard work with the DIY community!
Cheers, AJ |
#5 |
Very nice and simple, Why do you do this when I have a pair of Seas L22s that I am wondering if I can do something 'interesting' with!
#6 |
Amazing.
Now I guess you have a switch some where that enables/disables the motioan feedback. So my question is how does it sound when you throw the switch to the ON position ? Can you hear a big change ?
For me the past is not over yet. |
#7 |
Congratulations on the work you have put into this project. The idea of a cylindrical capacitive sensor works very well.
It is very linear and you can use various methods to measure the capacitance, including radio frequencies such as used in some condenser mics. The ibasic idea however is not novel so I would be doubly careful with your patent application. Andrew |
#8 | |
Well, of course this was only my own opinion that may be a bit biased. ![]() At lower levels effect is not so noticeable, since much of the speaker THD comes from spider/surround/motor nonlinearities that are proportional to cone deflection. Puggie: I don't see any problem with SEAS L22. It seems to have the same voice coil diameter as L18RNX. Some drivers however may not have enough "depth" between top of the voice coil former and pole piece to reliable attach the outer cylinder of the capacitor. I dont know if this is the case with L22's. I have done some experimenting with L26RFX/P and atleast there is plenty of room (and 51mm voice coil). |
#9 |
Very nice! I was looking to create and patent a slightly different motional feedback system. I like yours, as it is sensitve to small fluctuations of the driver cone, wheras most are only concerned with the gross level changes at high levels of deflection.
The reality of the human ear, is that it is the miniscule differences in peak levels -they are the 'intelligence' of how we actually hear. This means that your system has far more fidelity, to that 'ear' that 'we' actually use to hear things. Ie, measurements are important-- but their weighting/design is even more critical.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#10 | |
I actually first played with simple plate capacitor with other plate connected straight to the cone and other to the basket (so that the distance between them changed with cone deflection). Didn't really work as the capacitance was unlinear and very small causing noisy signal. And cone breakup caused chaotic sounds coming out of the system (this proto was with paper cone). |
| Motional Feedback Subwoofer | acoustic1 | Subwoofers | 41 | 19th September 2011 09:28 PM |
| Capacitive feedback, anyone tried this? | scott wurcer | Solid State | 22 | 3rd February 2007 12:57 AM |
| Examples of DIY motional feedback? | Mr Evil | Multi-Way | 10 | 21st November 2004 06:20 PM |
| Motional feedback subwoofer HELP | Johanson | Subwoofers | 3 | 1st February 2002 11:04 AM |
| Page generated in 0.15795 seconds (69.25% PHP - 30.75% MySQL) with 11 queries |
