Dear Sirs,
I would like to try to build a 3 way speaker able to reach down 50 Hz flat. I have some preliminary doubts anyway: 1) is it better to choose a cone mid or a dom mid? 2) any suggestion of a really great woofer? it should be reproduce the 50 Hz very strongly (read at least 95 dB/2 meters). Thank you very much indeed. Kind regards, beppe61 |
#2 |
Speakerholic
Sounds like you may want PA drivers.
What's the budget? How big do you want your boxes? Dome mids are not as effeicient as a good PA mid. What sort of tweeters do you like? There are so many things to consider that you have to give us some more info before we can really help. Tell us about what you are trying to achieve. |
#3 |
Perhaps a 2-way with sub? This is still a 3-way but allows you to use a wide range cone mid to cover the majority of the spectrum and crossover to a low-reaching woofer at a lower point than you could with a dome mid.
I really don't make a big distinction between a 3-way and a 2-way with sub - it's just semantics - you're using three drivers so it's a 3-way. You can have one sub unit per speaker, even built in to the main cabinets so it's all one speaker (though many like to isolate the bass from the rest). For the efficency you are looking for the PA idea may still be the way to go, but I can't make any specific recommendations.
Soft Dome |
#4 |
Speakerholic
Another question: What is your max SPL target?
I agree with CLC about the two way, three way thing, it's really just semantics. |
#5 | |
Dear Mr. Weldon,
please excuse my belated reply but I took time to clear my mind. I strongly think this discussion will help me very much. First of all I would like to say that I have thought about a 3 way system beacuse I do not think that is possible to reproduce accurately the range 50-20.000 with just 2 drivers. Am I wrong ? > Quote:
1) let's say frequency response 50-20.000 Hz +-3dB 2) good efficiency and easy load for the amp 3) good soundstage reproduction in the depth dimension But for instance I do not know if it is better to use a cone or a dome for the midrange. So the first step would be to select suitable drivers for the project. Thank you very much again. Kind regards, beppe61 |
#6 | |
Dear Sir,
thanks for the reply. I am still trying to choose the way to go. > Quote:
Once I read that to reproduce the full range from 20-20.000 a minimum of 4 drivers are needed (like in the JBL 250Ti for instance). Is it correct? Thank you very much again. Kind regards, beppe61 |
#7 | |
Thanks a lot. Kind regards, beppe61 |
#8 |
Speakerholic
Ok, if you need a narrow speaker then perhaps consider a thin floorstander 2 way with a separate woofer. Maybe a 6.5 woof and a dome tweeter. Do you have a spot to place a woofer box?
If you only need 90 dB then you don't need PA drivers (public address or pro drivers) as they are known for efficiency and toughness, not necessarily SQ. I would only recommend a dome mid if you have heard it and like it. It would be better in a three way without the separate woofer. Under approx. 80 hz is non-directional. I agree that if you have a separate woofer you should have a plate amp to power it. As CLC said, you can have the woofers and amp in the same cabinet as the rest. I have two sets like that, one with a dome mid. The picture is a 4 way and you can see the front and back. Maybe this is the way for you also. You can't make the exact speaker as I have used old and discontinued parts for these, but you can still do it with new if the idea appeals to you. It is really two cabinets in one. It's approximately 10" (25 cm) wide by 12" deep (30cm) by 44" high (112cm) It can be done for $800USD I also noticed I have repeated a lot of what CLC said, oops. Cal |
#9 |
More questions. Is it primarily for music or home theater? If music, what kind? I agree with the above posters that it does not sound as if you need special drivers for what you're after.
I would suggest that you look at kits; that helps get around the crossover design issue. In the US, Madisound speakers would be a good website to visit, and you could get a feel for cost and availability. Do ou have the tools and ability to build your own cabinets? They are also available as kits. And for a strong 50 Hz, I would go a little larger, to a good 8 inch; and actually if it is used for music I would suggest setting 40 Hz as the lower limit. It can be done with either a three way or a two way; I prefer three ways, with the mid crossing over at no more than 150 Hz, and the tweeter at 3kHz or so, which puts a real burden on the midrange, but makes woofer and tweeter choices a bit easier. And since most of the signal is in the midrange, it is a good place to put more money relatively. But there are MANY different approaches that work. |
#10 | |
Dear Mr. Weldon,
my sincere congratulations for your excellent work. Very nice speakers indeed ! > Quote:
thank you very much for your extremely kind and useful support. With your help I am clarifying my ideas. Thank you so much. Kind regards, beppe |
| Understanding Simple SE design choices | rockgardenlove | Tubes / Valves | 1 | 22nd November 2008 07:28 PM |
| Help with sub design choices | Micah Wells | Subwoofers | 27 | 12th February 2007 10:19 PM |
| Home Theater Combo - choices choices | smithsonga | Multi-Way | 1 | 2nd April 2003 05:11 AM |
| Page generated in 0.14277 seconds (83.49% PHP - 16.51% MySQL) with 11 queries |
