1. It is my understanding that a sound pattern emanating from a driver will change with changing frequency, specifically narrowing with increasing frequency. I also seem to recall, that the narrowing is dependent on the driver dimensions.
I was wondering if there are any references, describing how this change in pattern depends on the driver dimensions and frequency. In other words, given a dimension of a sound radiating surface of the driver and a frequency, can one predict the pattern? 2. It is my further understanding that the change in pattern can be controlled by a waveguide; however, the pattern will be controlled only down to a certain frequency [1] according to a formula: Fc= 10^6/(theta*X) where: theta is the included angle of the waveguide; X is the mouth width of the waveguide [in]. I fail to understand how to apply this formula to a waveguide that has several included angles a la MantaRay, or a curved mouth section a la Geddes. Should anyone know an answer, I would appreciate it. Thank you, M |
#2 |
http://www.pvconsultants.com/audio/radiation/arpe.htm
This program can assist you in estimation of the effects of frequency and driver radius. You can also find a spreadsheet that does something similar in the Unofficial Speaker Workshop Manual downloadable at www.audiodiycentral.com. I believe it is in section 5 or 6. Jay |
#3 |
Thank you very much Jay.
M |
| Confusing about grounding, please help | goldkenn | Chip Amps | 5 | 21st August 2008 04:20 PM |
| confusing transformer connections | audio_moksha | Tubes / Valves | 0 | 13th March 2008 03:07 AM |
| WE310A, a confusing issue | Kenneth Zhu | Tubes / Valves | 1 | 9th December 2006 02:24 PM |
| confusing capacitor value | wim | Parts | 10 | 28th February 2005 03:23 PM |
| Page generated in 0.06577 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
