Bose Driver Re-use?
Bose Driver Re-use?
Old 17th January 2006, 02:35 PM   #1
croat47 is offline croat47  United States
croat47's Avatar
Default Bose Driver Re-use?
I have some Bose 201's that I was going to re-build. Before anyone jumps on Bose products, please read on:
I also have some Dayton 1" silk dome tweeters. I thought perhaps I could use the woofers from the 201's, the Dayton tweeters, and some better crossover components (have those too) to make a nicer sounding speaker. I would eventually upgrade the woofers with some Vifa 6.5" drivers.
Cash flow, living situation (in-law's while we house hunt after our move from out of state), and time are my limiting factors. Has anyone tried this? I know that Bose uses cheap parts and construction (I already dissected one speaker and found NO solder at all: just pins wrapped with wire). But, this could be a band-aid while I wait for the Vifa's.
Thanks!
Old 17th January 2006, 04:07 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Bose Driver Re-use?
Of course that's OK. What are you really asking for? Forgiveness?
Just don't spend any money on them.
planet10 needs your help:
Let's help Ruth and Dave
Old 17th January 2006, 04:30 PM   #3
croat47's Avatar
Default Forgive me Forum for I have sinned...
Well, I guess it is forgiveness...
I plan on spending MDF and finishing on them. Everything will be geared (except the low pass portion of the crossover) towards replacing the Bose drivers with the Vifa's at some point...hopefully soon.
Have you done this...it's okay to admit it.
thanks!
Old 17th January 2006, 04:52 PM   #4
Speakerholic
Cal Weldon's Avatar
Bose Driver Re-use?
I'll admit to using old boxes with new gear. I will admit to friends owning Bose. I won't admit to using Bose myself.
Sometimes I will use old boxes of known size for testing different woofers. I make different baffles that I mount to the old cabinets.
There, I've come clean.
My name is Cal and I'm a speakerholic.
Old 17th January 2006, 05:03 PM   #5
croat47's Avatar
Well, the reason to even take apart the 201's in the first place was to (gasp) rebuild them. They had been beaten pretty severly over the 7 years of college. But, I had the tweeters and found some Vifa's I liked (which may be hard to find now, I hear). So, to get me by, I thought I would build the cabs and bide my time.
Perhaps you are aware, or not...of exactly how cheaply the Bose stuff is made. It's half-inch particle board glued together: there is no way to use these boxes in good concience. Yes, I know I was listening to them for years. I have discovered DIY and a finer ear.
Thanks for the support. Have you gotten your pin yet?
Old 17th January 2006, 05:28 PM   #6
Speakerholic
Cal Weldon's Avatar
Bose Driver Re-use?
Just to confirm:
You are building boxes for the Vifa's and want to temporarily use these new boxes to house the Bose/Dayton drivers until the Vifa's arrive?
You will be scrapping the Bose boxes.
You will be scrapping the Bose drivers once the Vifa's arrive.
If you have answered yes to the above questions, no one here will bother you about that. If you are then panning to do something with the Bose drivers, well my friend, you are on your own. Don't forget to duck.
And yes, sadly, I am familiar with the Bose level of quality.
Old 17th January 2006, 06:19 PM   #7
croat47's Avatar
Originally posted by Cal Weldon
Just to confirm:
Yes.
Yes.
Yes.
Somehow they keep selling them. The 901's were cool to hear when I was a kid at a friend's house. His dad had them and they kicked you in the chest. But, my dad's Infinite Slope's (?) sounded so much better with Dark Side of the Moon.
Thanks for the go-ahead!
Old 17th January 2006, 08:47 PM   #8
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Bose Driver Re-use?
Cal is much too nice of a person to outright forbid the use of Blose drivers. However, EVERY Bose driver I have ever come across (901 4" drivers barely excluded) deserved to be pitched straight into the dumpster. At best, I think you'll be disappointed and discouraged putting valuable time into a temporary solution with those drivers.
Even if low on funds, I would scrape and beg for some money to buy some Pyramid or Pyle (or whatever), rather than use old Bose drivers. Can't you find something on sale at David Levy (dlcparts.com), Madisound, or Parts Express? I've seen speakers at thrift stores and yard sales for next to nothing.
Philosophically, I also wouldn't pull apart a working speaker, even Bose, for parts. I'd rather give them away to somebody appreciative.
Please apply one of the follwing sayings to your situation:
If it ain't broke, don't fix it.
You can't make a silk purse from a sow's ear.
You can't polish a turd.
If it's worth doing, it's worth doing right.
Old 17th January 2006, 10:06 PM   #9
Speakerholic
Cal Weldon's Avatar
Bose Driver Re-use?
Tosh,
Thanks for the concerns about him using the Bose drivers but I think if you reread the post, you'll find that new cabinets are being built for his Vifa drivers and he's going to use the Bose drivers only until the Vifa's arrive. It's just a stop gap. He promises not to use them after the real drivers arrive.
Old 18th January 2006, 12:23 PM   #10
Mark Techer is offline Mark Techer  Australia
Mark Techer's Avatar
Send a message via ICQ to Mark Techer
Croat47,
So what exactly are you building? I maybe way off here, but do you intend to re-build (a better version of) the 201s from MDF and use Vifa/Daton drivers or something else?
The reason I ask is that in some way I see potential in direct/reflecting speakers if they used decent drivers and crossovers...
Mark
CIH Explained
Bose Driver Re-use?Hide this!Advertise here!
bose 901 driver surround repair replacement jaya000 Multi-Way 43 7th June 2013 03:18 PM
No, not Bose!!! j.burtt Multi-Way 26 24th May 2006 08:22 AM
He wants BOSE, HELP!!!!! paul stewart Multi-Way 4 28th November 2005 07:19 AM
bose 601 kostas Multi-Way 3 28th December 2003 12:37 AM
need driver specs for raw Bose drivers Jared Multi-Way 2 18th November 2002 01:44 AM
