Bose Driver Re-use?
Bose Driver Re-use?
Old 18th January 2006, 02:52 PM   #11
croat47 is offline croat47  United States
croat47's Avatar
I intend to build cabinets to house the Vifas, which are recommended for use in sealed cabs from 0.25-1.00 cuft. But, in the absence of funds to get the Vifas just now, I will use the Dayton silk domes and the Bose woofers to get sound out of the cabs in the short term. I may look for something on the reco'd sites from above. If I can find something better than the Bose 6.5" for less than the Vifas, tehn great! If not, I'll have to put up with it for the short term...the sound and the moderate to heavy ribbing.
To sum up: new cabs designed for Vifa or similar, new tweeters, Bose 6.5" for temporary solution, forward firing not direct/reflecting or omni-directional.
Still think I'm okay?
Thanks for the input!
Old 18th January 2006, 11:20 PM   #12
Mark Techer is offline Mark Techer  Australia
Mark Techer's Avatar
Send a message via ICQ to Mark Techer
If there (Vifa) range is from 0.25-1.00 cuft, then I would go for the higher end of the scale...
I did have this crazy idea once about re-inventing the 901 by using three 3/2 D'appolitos' arrays in the same box with one set firing at the listening posion and the other two firing off at 60 degrees (an equalateral triangle in plan) to provde 9 drivers that had high produced from actualy tweeters and not the dome shaped dust caps of multiple wide range drivers. I never built them, but have though about it...
Whilst I would never use such a design in HT, for a music only system, the direct/reflecting concept has some merrit. I just want to hear it with decent drivers...
Mark
CIH Explained
Old 18th January 2006, 11:25 PM   #13
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Bose Driver Re-use?
Yes. If anyone gives you any kind of guff, you just send them my way.
planet10 needs your help:
Let's help Ruth and Dave
Old 18th January 2006, 11:30 PM   #14
Speakerholic
Cal Weldon's Avatar
Bose Driver Re-use?
Folks, I might need some help here, I think we're losing one. If anyone lives close to Mark see if you can help him and get back on the right road.
Actually Mark I think most of us had visions of that at one time or another.
Just couldn't find any of them there one ohm drivers nowhere, no sir.
Old 18th January 2006, 11:40 PM   #15
Thanks Carl, but I'm OK now.... It must have been on of those momentary lapses of reason...
Mark
CIH Explained
Old 19th January 2006, 12:56 PM   #16
croat47's Avatar
Good...I was planning for the higher volume. Better bass extension and dynamics, right? I will be building a sub eventually, so I am not too worried about the lower register.
Thank you Cal and Mark for the input!
Old 19th January 2006, 11:35 PM   #17
Well good luck with that and we look forward to reading about the vifa drivers soon...
Mark
CIH Explained
Bose Driver Re-use?Hide this!Advertise here!
bose 901 driver surround repair replacement jaya000 Multi-Way 43 7th June 2013 04:18 PM
No, not Bose!!! j.burtt Multi-Way 26 24th May 2006 09:22 AM
He wants BOSE, HELP!!!!! paul stewart Multi-Way 4 28th November 2005 08:19 AM
bose 601 kostas Multi-Way 3 28th December 2003 01:37 AM
need driver specs for raw Bose drivers Jared Multi-Way 2 18th November 2002 02:44 AM
