Old 3rd September 2012, 01:19 AM   #11
Plus they all have cast frames and your not paying a arm or a leg for it. Mr. Jeff
Old 3rd September 2012, 01:30 AM   #12
I don't know if this helps you or not, but I did run them in my previous SUV with the BG NEO8 and thought it sounded good as a 2way system.
Old 3rd September 2012, 01:38 AM   #13
fakeout is offline fakeout  Canada
fakeout's Avatar
Originally Posted by Zaph View Post
The cones are generally pretty good. They are a bit more rigid than the average paper or carbon fiber, and they do have breakup nodes. The surrounds and frames of the Silver Flute woofers are also very good, but the motor assembly is generally low tech. Just a straight flat pole piece without any special geometry. As such, harmonic distortion is only average or slightly higher, and Le is kinda high too. Overall, the woofers are a good value, considering the low cost.
ps. The Silver flute planar tweeters suck however.
Here's one project with the 5.5":
Zaph|Audio
This project is no longer available. For those that have saved copies of this project, please do not distribute.
What the hell kind of decision is that? Corporate? People want free plans dammit!
I usually don't want to whine but...
Feeling Good by David Burns
Old 3rd September 2012, 01:47 AM   #14
Melo theory's Avatar
I'm going to do an open baffle with the 8" in a month or so, I have to do a line array first, I will post results on the OB when I'm done.
I LIKE YOU
Old 3rd September 2012, 08:57 AM   #15
Jay is offline Jay  Indonesia
Surprisingly good in almost all aspects. No complaint at all, except for sensitivity. So I use them for my active crossover projects.
Old 3rd September 2012, 01:17 PM   #16
norman bates's Avatar
I like the 4ohm 8" 93db driver crossed at 2khz.
I am running the w17rc38s08 (shielded 8ohm) right now crossed at 5khz 24db.
Granted dispersion narrows going past a couple of khz (6.5").
It is very good for the money, but I should cross it a bit lower.
I'm sure I could do better, but not for $30.
I think people liked a hivi driver more.
I couldn't get the 8" to cross at 5khz, just too hashy up there for my ears nowadays.
To me, the drivers sound smooth, non offensive.
Norman
Old 4th September 2012, 10:32 PM   #17
fakeout's Avatar
Here's a weird one, what's the web site for Silver Flute?
Old 5th September 2012, 12:13 AM   #18
weiyan is offline weiyan  Hong Kong
http://www.yindi.com/
Woofer
Web side design is not intuitive.
The part no. is not the same of Madisound.
Old 5th September 2012, 12:23 AM   #19
I highly doubt it is the same SF we are talking about
Old 5th September 2012, 03:17 AM   #20
Reasonable doubt.
Õý×ÚÒøµÑÅÆ¸ßµµ6.5´çµÍÒôhifiÒôÏäµ¥ÔªÀ®°ÈÑïÉùÆ÷167-1506X2-ÌÔ±¦Íø
They have same looking and same wool cone. The price about half of Madison.
FE126E + SF Wool Cone Finally Finished! musgofasa Full Range 9 5th December 2008 05:28 PM
WTB: Silver Flute W17RC38-S 6-1/2" Wool Cone - Shielded Thror Swap Meet 1 28th September 2008 02:20 AM
silver flute 5.5 as mid. chainenoble Multi-Way 1 25th September 2006 04:09 PM
Silver Flute Eight Inch Mats J Multi-Way 3 11th July 2003 01:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
