i am building the crossover for the zaphaudio.com hivi b3s projects, i am building it exactly to his specifications
the inductors i am using are madisound air core inductors...and the coils have tape wrapped around them I know i need to adjust the .1 mH inductor to be .08mH, so i will have to remove some coils....my question is, do i replace tape around the coils when i am done? does the tape serve any purpose? do i need to remove the tape off of the .8mH inductors, even though i dont need to adjust those? i wont touch em till somebody gives me an answer... |
#2 |
while we are at it, i am having trouble calculating how many turns to unwind...he said to use that online calculator, found at this link:
http://www.lalena.com/audio/calculator/inductor/ but i dont know what values to enter for the coil diameter and coil lengh....this is the inductor i bought: http://www.madisound.com/cgi-bin/ind....19618&pid=567 and it says this under item description: 0.1mH Inductor 19 awg Air Core Medium Bobbin 48mm Ø x 23mm T somebody please help! |
#3 |
48mm is the diameter and 23 mm is the height.
Coil length, I have no idea.
DIYaudio for President ! |
#4 |
ok...so is the only way to find coil length to unravel the whole thing? there has to be a better way...
also, what about that tape? |
#5 |
Dunno about the tape, that's why I didn't answer the first time. I think you can safely remove it but I would prefer if someone else confirms.
To get coil length, you could do this... pi x diameter = length of a single turn length of a single turn x number of turns = total length
#6 |
now THAT is a darn good idea...thanks simon5...or should i say sir...
anyone else about that ol' tape... |
#7 |
You can estimate the wire length by measuring the resistance. That inductor probably has a resistance of around .15 ohms. 19awg copper wire has a resistance of .008051 ohms per foot.
.15 / .008051 = 18.6 feet I measure my inductors using speaker workshop, but this method should work too. Dan |
#8 |
so doi just assume that it is .15 ohm or do i look it up? how would i actually measure an inductor using a computer program?
now what about that pesky tape?!/! |
#9 | |
http://www.apexjr.com/new.htm Hong |
#10 |
Can't measure a really low resistance like that directly with a multimeter, sorry, unless you pay several hundreds $$$.
| best practices in building a crossover | doug20 | Multi-Way | 3 | 9th July 2009 07:45 AM |
| Building a Crossover | wolfsvein | Multi-Way | 2 | 22nd January 2009 03:39 AM |
| Help building 3 way crossover | MAXIMUSuk | Multi-Way | 3 | 2nd July 2008 06:23 AM |
| help building a 3 way crossover | harrisni | Multi-Way | 6 | 25th September 2006 03:50 PM |
| Crossover building question | shaunly | Parts | 0 | 8th September 2005 05:31 AM |
| Page generated in 0.10173 seconds (76.17% PHP - 23.83% MySQL) with 10 queries |
