Woofer Tester I
Woofer Tester I
Old 16th January 2006, 06:09 PM   #1
69stingray is offline 69stingray  United States
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Default Woofer Tester I
Does anyone know or have experience with using the WOOFER TESTER I with Windows XP? Can I run it from the DOS prompt (using command.com)?????
Old 16th January 2006, 07:29 PM   #2
Gary P is offline Gary P
Gary P's Avatar
If it is the origonal Woofer Tester, not the new USB version, the answer is a big no. The way the software driver is written it needs direct controll of the printer port, somthing that is not possible with NT/2000/XP.
Woofer Tester was written for straight DOS. The only windows versions that can be used with the Woofer Tester are Win95/98/ME and most likely Windows 3.1.
I still have an ME install for my lab PC on a hard drive that is in a swap bay for when the Woofer Tester is needed. PITA!
Gary
Old 16th January 2006, 09:14 PM   #3
jaymz168 is offline jaymz168  United States
jaymz168's Avatar
Try a DOS emulator, here are a couple of examples :
http://bochs.sourceforge.net/
http://dosbox.sourceforge.net/
These are both free, and available for many OSes, but I believe you need to compile both of these (you download source code, not binary code, requiring a compiler, like gcc). If you're not comfortable with that, do a google search, there are loads of programs like that around. Since the math is so important in your program, make sure you find one that emulates a slower computer, so the maths don't get messed up, and this prevents all kinds of other problems as well. Then you just run the emulator, and run the proggy from within the emu, and you're golden.
Woofer Tester IHide this!Advertise here!
woofer tester & LMS difference mhtplsh Subwoofers 3 13th January 2008 04:24 PM
Woofer tester 2 sweepstakes oldbar Multi-Way 0 15th December 2007 08:30 AM
Dayton Woofer Tester II Anyone try this? Zero Cool Multi-Way 5 14th May 2006 02:09 AM
Woofer Tester John L Multi-Way 2 30th October 2001 03:44 PM
Copyright ©1999-2017 diyAudio
