Modifying Ariels (going active)
Old 16th January 2006, 12:03 PM   #1
Ninfendo is offline Ninfendo  Hong Kong
Default Modifying Ariels (going active)
Hi Everybody,
I have previously poseted onformation on my Ariels which incorporates the Almighty Subwoofer:
http://www.diyaudio.com/forums/showt...395&highlight=
I am now trying to replace the existing crossover with an all active design using BruteFIR on a PC which does all the filtering.
However one worry is that the PC sends out bass signals on power ON. This is also a problem with the AMP6 from 41hz I am using. I am currently consifering different methods of getting around this problem.
I would like to use fairly steep filters (4th order), so my idea would be to use one capacitor for the tweeter and then implement a 3rd order filter using software. This would equal a 4th order filter.
I would be interested in peoples opinions on the matter, also what crossover frequency and cap value should I choose?
Old 16th January 2006, 02:49 PM   #2
ezkcdude is offline ezkcdude  United States
If you don't mind me asking, what soundcard are you using, and what are the outputs? Also, what is the user interface that you would use to play songs?
Old 16th January 2006, 05:18 PM   #3
Soundcard: M-AUDIO - Delta 1010LT
Software: MythTV playing FLAC files from hard drive
Modifying Ariels (going active)Hide this!Advertise here!
modifying KRK/Stanton Active speaker wleediy Multi-Way 0 30th January 2008 11:01 AM
My Ariels GazzaFloyd Multi-Way 11 9th August 2005 02:00 AM
Sub woofers for Ariels chrish Subwoofers 4 1st May 2005 01:56 AM
Design basis for Ariels? Gaber Multi-Way 7 24th April 2002 04:08 PM
Ariels with AKSA? BigDan Solid State 0 21st December 2001 06:07 PM
