Old 3rd August 2006, 01:01 AM   #31
Pulse-R is offline Pulse-R  Australia
Back to the 'how to boost a signal without losing bits' question...
If the signal is below 0dB at that frequency where the boost is occurring then boosting at that frequency will not clip the signal at that frequency.
However, if the overall signal has now increased above the 0dB limit then clipping will occur.
to improve S/N on my DCX2496 I have run the inputs (digital) at -1dB and boosted the crossovered outputs up to +6 or +8dB. Each output still does not clip with a 0dB input, because each output is only reproducing a small part of the total spectral signal.
Digital is only on or off
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
TMM 2.5 way with digital crossover sqlkev Multi-Way 7 10th May 2006 10:53 PM
Get digital signal from an old CD-Rom without digital output genome Digital Source 5 3rd February 2004 11:54 PM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.07113 seconds (64.85% PHP - 35.15% MySQL) with 10 queries
