Old 15th January 2006, 12:13 AM   #1
Default Is this what I need to extend the reach of my 2 rear speaker satellites?
Just Purchased a "Logitech X-530 5.1 Speakers System" as seen >>here<<, however the leads on the satellites that connect to the sub/control unit are not long enough (has to be f/m as the leads are fixed to the satellite speakers.
After ages searching and trying to find the right extension leads I have come across this: http://www.jaycar.com.au/productView...=&SUBCATID=567
Is this what I need?
thanks for any help
Old 15th January 2006, 02:31 AM   #2
Send a message via MSN to noodle_snacks
if the plugs on the back of the logitech unit are RCA plugs (many of them are) then they would technically work yes, you will probably want a male to female cable, to extend the leads
edit: your other alternative, depending on if speakers are glued in or screwed in, is to unscrew the drivers, de-solder the original cable, then solder your own in place, i did this with some old altec lansing 641 rear surrounds years ago, whilst also stuffing the satelite boxes with polyfil.
Old 15th January 2006, 03:11 AM   #3
cheers for the reply
but im not a soldiering guy
What Im after is a Female to male RCA extension lead (to make the distance from the speakers to the base/control box longer). The Leads are glued to the speakers so can not be replaced.
Im just not sure if this item that I linked to above is a Male to Female RCA cable or something else (it says RCA to RCA, but not F to M), so was wondering if anyone else knew if it was?
cheers
Old 15th January 2006, 03:32 AM   #4
Speakerholic
Cal Weldon's Avatar
If it doesn't say, it's likely a male to male. If you can't find F to M then you can use those but you'll also need the little female to female connector and I don't see that on their site
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th January 2006, 03:35 AM   #5
Speakerholic
Cal Weldon's Avatar
Here's one at PE
http://www.partsexpress.com/pe/showd...number=090-282
Old 15th January 2006, 03:53 AM   #6
coooljono just go into your local jaycar or dicksmiths, they should have what you need.
Old 15th January 2006, 04:00 AM   #7
Speakerholic
Cal Weldon's Avatar
the censor catchs that one. He wrote d-i-c-k s-m-i-t-h-s.
Old 15th January 2006, 04:14 AM   #8
cheers noodle_snacks, was just leaving dcksmiths as a last resort tho as from what I remember they are a rip off and all these hidden costs are killing me lol (had to buy a ceiling mount and a 10m VGA cable for the projector also + new curtains with blackout cloth ). as for Jaycar I dont think there are any near by.
lol yeah Cal Weldon i actually didnt even realise it was censored till u pointed it out haha.
And cheers for the link to the item, ill keep it in mind that I can use one of those (if i can find one in aus) if i can only get a male-male RCA cable.
Old 15th January 2006, 04:38 AM   #9
Ive come across this also:
http://www.techflare.com.au/sales.as...bcat=2&search=
It is made for 2 speakers, so only need one for both the rear speakers, however it only 1.8m so I would need to buy 2 (costing $30pp), so will keep exploring my options, but at leads i hae somethign now .
edit:
wootaaa
http://www.pcsol.com.au/orders/order_cart.asp
2 speakers = 2 cables = $10pp
I hope the audio quality wont be effected tho, any comments on this ?
Old 15th January 2006, 06:08 AM   #10
opps here is the item:
http://www.pcsol.com.au/6ProdDetail....hortdesc=Audio
not the cart
Guido Tent hard to reach? Ryssen Digital Source 4 13th February 2007 09:03 AM
Designing a rear surround speaker pjpoes Multi-Way 7 4th February 2007 12:33 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
Dipole / Bipole rear effects speaker NicolasGaal Multi-Way 1 4th January 2004 09:16 AM
Rear speaker - feasible??????? rabbitz Multi-Way 24 11th August 2003 04:50 PM
Page generated in 0.10470 seconds (78.77% PHP - 21.23% MySQL) with 10 queries
