Old 14th January 2006, 09:45 PM   #1
mazurek is offline mazurek  United States
Default audibility of full 360 degrees phase shift
Is a full 360 degrees phase shift audible?
I am making an active crossover, and it requires an allpass delay. The tweeter must be delayed 190 us according to measurements, and I could use two stages of the filters shown here http://www.linkwitzlab.com/filters.htm#4. However, if a 360 degree phase shift is inaudible, then I could instead delay the midrange by 60 us to make the waveform a full 180 degrees behind (250 us = 1/2 wavelength at crossover), and then invert the polarity to total 360 degrees shift. Putting a shorter delay circuit in the midrange would result in much less phase distortion due to the allpass delay filter.
What do you all think.
Thanks,
Lee
Old 14th January 2006, 09:56 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Do you have the option of moving your drivers to achieve delay?
Old 14th January 2006, 10:03 PM   #3
Not in a box made by parts express and without any tools, unless I tilt it 30 degrees and listen to it all off axis.
Old 14th January 2006, 10:09 PM   #4
poobah's Avatar
Your 360 phase shift thing will work just fine... I have used similar tricks in high-end car stereos where woofers were in the rear tweets in front etc... it works.
And good job of thinking outside the cone...
Phase shift smps topology darkfenriz Power Supplies 12 10th August 2008 11:30 AM
Zero phase-shift gareth Solid State 11 9th May 2008 04:45 PM
Signal phase shift through a tube amp d1camero Tubes / Valves 8 13th November 2006 03:18 PM
Hybrid amp phase shift oscillation? Duo Solid State 5 21st October 2004 08:16 AM
Zen Phase Shift, Feedback in BOZ Jay Pass Labs 3 17th February 2003 04:36 AM
Page generated in 0.07543 seconds (69.26% PHP - 30.74% MySQL) with 10 queries
