Old 13th January 2006, 09:25 PM   #1
hurdy_gurdyman's Avatar
Default New open baffles
Haven't been here a lot lately, but thought this could be of interest to some of you.
http://pg.photos.yahoo.com/ph/the_hu...yman/my_photos
I received my new Hawthorne Audio Silver Iris speakers Tuesday evening. Wednesday morning I headed for the woodshop (had to sweep away a few cobwebs). Had a piece of MDF big enough for most of the new open baffles. Had to make a trip to the lumber yard for the pine board I'm using for the top and bottom. I consider the entire project a "throw together" until spring when I'm planning on building a better pair. I still need to make a padded grill cloth to cover the beast.
Now that I've had them up and running for a few hours I'll give my initial impressions.
First off is a small caution. With my old Scott amp there was a problem. With recordings that have lots of bass, the speaker gyrated in and out uncontrollably, causing everything up through the mids to sound garbled a bit. This didn't surprise me much, as the Scott has shown itself to be poorly damped on a few other speakers. The Scott is a classic push-pull full bore pentode amp. These typically have poor bass damping. It hadn't been a problem with my EV's and Heresy's because they both didn't produce any deep bass. The Silver Iris has a lower fs than my EV's and has no box for damping like my Heresy's had (Heresy's have a low 0.35 Qts driver and don't need any amp help). The Silver Iris has a high Qts of 0.9 plus a crossover inductor between them and the amp. I'd quess this is a bit much for many classic pp amps. It shouldn't be a problem with decent triode or ultra-linear amps.
My solution was to put my Sansui receiver (used as a preamp) back into service and hook up my harman-kardon citation 16. This 70 pound monster is a dual mono solid state beast putting out 150 watts per channel and has damping out the wazooie. No compatibility problem now. ;D
Now to the sound.
These things are AWSOME! Period.
They are about the same sensitivity as my EV LS-12's (maybe a decibel or so more) The rating of 95 dB sounds right. Bass is deeper and cleaner than my EV's, although the EV's did a good job with the old Scott as well as the harman-kardon. The EV's had a bit of a "bump" in the 80Hz range. I haven't measured the Silver Iris's yet, but I suspect they don't have this. They extend deeper noticably, but I haven't measured this yet, either. I'm too busy listening to do any measuring yet. ;D Mids are more open sounding than my EV's. The difference is very noticable, but not huge. Detail and transparency are better than the EV's, but again, not by gigantic margins. They do sound like they are in a league with many other speakers I've heard the last few years that need fancy boxes to get any real bass. These do it in simple OB's. I'm guessing I'm getting around 50 or so Hz in my OB's, and at clean high volume levels. This is very good for a modest sized OB. If I run my Cerwin-Vega home-made sub, it being on barely makes a difference on the rock and folk I've listened to. I suspect a lot of movies will benefit form a sub of some sort.
Treble is very clean. Very airy (at least as high as my poor worn out ears can hear). Cymbals are very clean sounding. As far as clean sounding goes, everything seems to have a very clean and open sound. Very natural. And it's getting better. Over the last few hours I can hear things opening up even more. I bet in a week or two things will get even better (they're pretty darn good as is). And, don't forget, this is all being done with open baffle’s wonderful soundstage, big and open! This is the number one reason to get an open baffle.
This is, by far, the best sounding open baffle system I've heard yet. I'd love to hear the 15 inch bass driver that is available to go with this in the same baffle. You'd never need a sub at all with that. Maybe I'll have to save my pennies up for a pair of those...
Looks like I can pack away my EV's for good. Won't be needing them anymore.
Here's the Website for Hawthorne Audio's drivers.
http://hawthorneaudio.com/
Dave
The only thing I like better than the sound of a banjo is the sound of a cat having a shampoo in a flushing toilet!
Old 26th September 2007, 05:15 AM   #2
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Hi all,
I have been unable to log into Hawthorne Audio's website for the past few days. Has it's URL changed?
...still looking for the holy grail.
Old 26th September 2007, 01:15 PM   #3
I had no problem yesterday, but today I can't even bring up forum at all. Must be having technical problems. I'll check with Darrel or Jerry and see what's going on.
Dave
Old 26th September 2007, 02:22 PM   #4
OK, it seems that they are having a problem, but should be back on in a few hours.
Dave
Open Baffles at RMAF-07 Pano Multi-Way 27 18th August 2008 01:08 AM
WMTMW Open Baffles Magnetar Multi-Way 47 14th November 2007 02:20 AM
$7 open baffles... planet10 Full Range 31 8th May 2005 07:45 AM
Open Baffles :- ) brianon Multi-Way 17 3rd February 2004 08:13 PM
Open baffles? dc Multi-Way 5 28th December 2001 02:10 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
