Old 13th January 2006, 08:44 PM   #1
Send a message via AIM to FSULongM
Default Newb spkr/passive radiator rebuild question
Search did not turn up a readily available answer - sorry if I missed it.
Replacing foam surrounds and dust caps on an old set of speakers (2" tweeter, 8" driver, 8" passive radiator) for my son and have a simple question:
Do you glue the foam surround to the PR cone?
Existing speaker surrounds are dry-rotted and difficult to examine conclusively, but :
1. Both driver and PR foam surrounds are glued to top of basket under gasket
2. Inside diameter of driver surrounds show some evidence of glue on top, suggesting they were once glued to bottom of driver cone
3. Inside diameter of PR surrounds don't seem to show any evidence of glue on top or bottom, so it suggests maybe they were under the cone but not glued or attached to it
I'm confused, does not gluing them to the cone serve as the vent and help move air, or not?
Thanks in advance for your help.
Old 16th January 2006, 08:14 PM   #2
Sorry, I am replying to my own post since no one else has, to move it back to the front page for one more try. Is there no one out there with any experience replacing the foam surround on passive radiators?
Old 16th January 2006, 09:42 PM   #3
Speakerholic
Cal Weldon's Avatar
Default Re: Newb spkr/passive radiator rebuild question
Sorry to miss this first time round.
Yes, the same way as with a driver.
[i]maybe they were under the cone but not glued or attached to it[/B]
They were glued.
[i]I'm confused, does not gluing them to the cone serve as the vent and help move air, or not? [/B]
No they must be glued to prevent stray air from escaping. The cone does the moving of air.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 17th January 2006, 06:53 AM   #4
Thanks so much. ml
passive radiator question krikus050 Multi-Way 7 5th October 2008 06:53 PM
Newb Passive Preamp Question s0rce Solid State 1 18th November 2006 02:24 PM
Peerless 10" XLS finished- passive radiator question tktran Subwoofers 2 30th May 2005 12:01 AM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 07:44 AM
Subwoofer and Passive Radiator question... WolfmanX Subwoofers 0 19th November 2002 01:10 PM
Page generated in 0.07038 seconds (82.96% PHP - 17.04% MySQL) with 10 queries
