Old 12th January 2006, 03:03 PM   #1
NickZ is offline NickZ  Canada
Default Measuring drivers with a multimeter? Question about Fl FH
I'm waiting for my microphone bits so I thought I would try using the multimeter. This is the website I'm following along with.
Measuring Loudspeaker Parameters
I think I'm doing fine until I hit
"Complete the measurements for Fl and Fh, for which the voltage across the source resistor is equal to Vr"
Okay if I understand this I change the frequency until the voltage read on the meter is equal to Vr. Fine. But what are Fl and Fh? I thought at first I would just measure the frequency like I did for Fs. But that's only one number not two.
Now less of a problem but still a wonder for me.
"First, measure the resonant frequency. Adjust the frequency until the voltage across the resistor reaches a null (minimum level)"
Just how low should I go. I can get it down to the point my meter is the issue. But I'm doubting 13500 is the frequency for the midrange I'm testing. So how low a minimum level do I need?
Old 12th January 2006, 03:11 PM   #2
owdi is offline owdi  United States
owdi's Avatar
13,500 sounds very wrong, you have passed the impedance peak. Voltage is getting lower because after a point the impedance of the voice coil rises with frequency. If you're measuring a midrange the voltage drop and impedance peak should be somewhere between 40 - 1000hz.
Dan
Old 12th January 2006, 03:14 PM   #3
Did it Himself
richie00boy's Avatar
Fl is the frequency below resonance where the voltage is equal to Vr, conversely Fh is the frequency above resonance where the voltage is equal to Vr. The span will not be more than about a couple of octaves from Fl to Fh, e.g Fl = 23Hz, Fr = 47Hz, Fh = 84Hz
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 12th January 2006, 03:17 PM   #4
Thanks to you both. Makes a lot of sense.
Really stupid multimeter question Dan2 Equipment & Tools 7 20th April 2008 04:11 PM
Measuring ac amperage with multimeter ccdoggy Equipment & Tools 6 27th December 2007 10:55 AM
A question about the Radio-Shack (Tandy) 22-175b digital multimeter gaetan8888 Equipment & Tools 1 1st December 2007 01:26 PM
Help measuring drivers! pat_staunton Multi-Way 6 21st July 2005 08:16 AM
MultiMeter question Tensop Parts 2 19th February 2005 08:10 PM
Page generated in 0.07720 seconds (67.15% PHP - 32.85% MySQL) with 10 queries
