Old 12th January 2006, 01:21 AM   #1
Default question about speaker box design
well i am FINALLY learning how to use winisd and the t/s parameters in general and now i have figured out how to decide how much internal volume is needed to get a speaker to perform a certain way...
NOW my question has to deal with the actual box construction...say we want an internal volume of .1 cubic feet for a small sub application...if we are using half inch MDF for the project, we would have to subtract half an inch off of each of the outer dimensions to calculate internal volume, right?
also, since the sub frame/magnet displace air once installed, shouldnt we keep that in consideration and add its equivalent volume to the overall box volume?
finally, what about a plate amp? simillar to the sub question, having a plate amp takes up space that was intended to be air for the sub...should we add this volume to the total internal volume?
so what i am asking is, should we use *calculated internal volume+estimated volume of sub+calculated volume of plate amp* = actual internal volume needed in this project?
Old 12th January 2006, 01:59 AM   #2
You got it. What ever your inside dimensions are determine your volume. WxHxD=Volume
No, you subtract their volumes.
Nope. Change your +'s to -'s and you'll be ok.
Old 12th January 2006, 02:05 AM   #3
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
I think you are both right....
If the required internal volume is 0.1 ft3, then you add the volume of the driver and the volume of the port. Lets say you est. the volume of the driver to be 0.05 ft3 and the volume of the port to be 0.01 ft3. You will want to determine what WxHxL dimensions get you the total volume.
Total Volume = Req. Volume + Driver Volume + Port Volume + Brace Volume.
That way, your NET volume is what yuo want.
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 12th January 2006, 02:10 AM   #4
For the net volume of a box you subtract the volume of anything that takes space inside the box. Including the driver, bracing and the port as well. Whatever you put in there can't add to volume....it subtracts.
Old 12th January 2006, 02:10 AM   #5
whoa...i am supposed to add the port volume too?
i didnt know that
can i get a second opinion
Old 12th January 2006, 02:18 AM   #6
I do, I have an Excel spreadhseet. It has the formula for the required port diameter and length and automatically determine's it's volume. I also add the major dimensions of the driver and it calculators the driver volume. It adds all the volumes together (include braces) to get the required internal dimensions, then adds 0.75" (MDF) to get external dimensionals. I love Excel.
Audio DIY Page
Old 12th January 2006, 02:29 AM   #7
69stingray and I are saying 2 diff things. I'm stating a basic fact about speaker box volume. He's saying how you come up with a specific volume needed for the driver to opperate at the frequency wanted.
Example. The driver needs 2 cu ft. You know your bracing, port and back side vol of the driver equals 1 cu ft. To get your 2 cu ft for the driver you add the 1 cu ft to your design. So you build a 3 cu ft box that has a net vol of 2 cu ft.
Old 12th January 2006, 02:33 AM   #8
ok ok, now i do understand...i am glad somebody pointed out the port thing before i made a mistake...
now about that excel sheet thingymabob...what say you email it to me
speaker box design physics question priscared Car Audio 4 18th November 2005 11:07 PM
A couple question regarding speaker design audioaction Multi-Way 2 27th January 2004 12:14 AM
Gainclone & speaker design question. Newbie looking for help! matjans Multi-Way 13 19th October 2003 05:31 PM
Speaker Design Question r.mcnamara Multi-Way 7 8th December 2002 11:26 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10659 seconds (79.84% PHP - 20.16% MySQL) with 10 queries
