I don't have one,
We don't have one at work, The guys in the design house next door don't have one. My subcontractors don't have one, I only want it once. (ok maybe twice). Could anyone measure a coil for me please? |
#2 |
I do not know how exact this coil measurement must be.
Unless you need it amazingly accurate, you can measure a coil yourself using a simple multimeter, analog or digital. Such multimeters are available quite cheaply, going as far down as $10 here-probably not much more there. You would need the use of a signal generator. Here is an excellent online signal generator. http://www.satsignal.net/ Audio Tools =>Sweepgen
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#3 |
If you're still coming down to Chatham I'll measure it for you.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
you can do this with one dual-opamp:
The sound card impedance tester The LMS test set uses a dual opamp to compare the voltage drop across an unknown impedance and an acurately known resistor. It is remarkably simple. You can test inductors, capacitors, transformers, negative impedances, etc. A PDF of the QEX article is available at www.arrl.org/qex/2005/Steber.pdf the code can be downloaded at http://www.arrl.org/files/qst-binaries/ just look about 1/3 down the page |
#5 |
Al, I get down that way about once a fortnight. If I don't get any joy in the next 2 weeks I'll deffinatly take up your offer. The gig I was going to was cancelled because the guitarist broke his arm. There will be others sometime though.
Thanks to the other guys. I don't really want to get into special projects for this. I'd probably need to borrow a meter to varify the calibration anyway! One of my suppliers has a huge flying probe PCB test machine. I might call in that favour.
#6 |
diyAudio Moderator Emeritus
I have an old Marconi Instruments RLC bridge TF2700 you could use. I'm located in Leighton Buzzard, Beds.
Send me an email if you are interested. |
| Wanted: Inductance meter, inductors. | Spasticteapot | Swap Meet | 14 | 30th October 2007 03:18 PM |
| inductance meter from a cheap meter? | jarthel | Parts | 3 | 22nd September 2006 06:37 AM |
| Inductance Meter | gmilitano | Multi-Way | 15 | 3rd October 2004 08:53 PM |
| LCR meter to measure inductance | SimontY | Parts | 14 | 22nd April 2004 05:47 PM |
| Inductance Meter | RobPhill33 | Equipment & Tools | 4 | 29th March 2003 08:45 PM |
| Page generated in 0.09329 seconds (74.54% PHP - 25.46% MySQL) with 11 queries |
