Old 10th January 2006, 06:06 PM   #1
baggins is offline baggins  United Kingdom
baggins's Avatar
Default my little speakers
Ive just put together some small speakers using a 5" ex-wharfedale
diamond 6 bass /mid :- qms=2.7, qes=0.57, qts=0.47,mms=7.48, cms
=1.05, vas=9.05, fs= 56.7 hz. At the moment there in tiny I.B. 13" x 7"
x 6" boxes and sound incredible for their size .My question is would it
be worth porting such a tiny box?
heretics are sometimes right
Old 11th January 2006, 09:06 AM   #2
its the internal volume that counts.
/sreten.
Old 11th January 2006, 11:27 PM   #3
baggins's Avatar
Thanks for the info,
If I interpret the graphs correctly does this mean that the -3db
point for the 3 situations is as follows :-
I.B. - 90 hz
ported box (this size tuned to 40) - 70 hz
ported box (twice the volume ) - 60 hz
I hope Ive understood this and if so how would I determine the port dimensions to achieve the 70hz , -3db case.
Thanks so much for your help!
Old 12th January 2006, 09:33 AM   #4
probably best to tell me the actual internal volume of your speakers.
Giving you the port dimensions for a 7 litre cabinet is not accurate.
/sreten.
Old 12th January 2006, 11:10 PM   #5
baggins's Avatar
Hi ,
I guess 5.8 litres allowing for the volumes of the drive units.
Bill.
Old 13th January 2006, 08:56 AM   #6
the point of reflexing is getting very marginal with 5.8 litres.
However for 40Hz a 25mm inside diameter vent is 14cm long, 30mm - 20cm.
/sreten.
Old 13th January 2006, 09:05 AM   #7
Did it Himself
richie00boy's Avatar
25mm diameter is pretty small for that size of drive unit, but tuned that low it might be fine.
However, accomodating a vent of that length in such a small box will prove interesting Probably have to find some 90 degree elbows, or careful splicing of the pipe as I think 25mm joints are rare?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th January 2006, 09:21 AM   #8
Personally I wouldn't reflex them, if anything I'd add a mini sub (or two).
90 degree bends in ports are a very bad idea.
A far better solution is a flexible tube with a gradual curve,
e.g. the output hose from a washing machine / dishwasher.
/sreten.
Old 13th January 2006, 09:43 AM   #9
Did it Himself
Wouldn't the serrations on the washer hose cause turbulence?
Old 13th January 2006, 10:58 AM   #10
Well you do get a B&W "flowport" on the cheap, /sreten.
Studio monitor speakers as Hi Fi speakers? MRod Multi-Way 2 27th March 2009 05:07 AM
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
How would you compare your DIY speakers to commercial speakers? AJ Bertelson Multi-Way 20 28th May 2004 03:20 PM
Car Speakers in Theatre Speakers NEED HELP FAST!!! Psionic Multi-Way 9 3rd March 2003 11:11 AM
Page generated in 0.14282 seconds (57.53% PHP - 42.47% MySQL) with 11 queries
