Dear Experts,
I am measuring a Scan Speak mid woofer (8530K00) and do not reach the Fs indicated by the manufacturer. 30Hz are the indicated by scan speak. my measurement results around 34hz. speakers are burnt in several days, measuring stripes are very short etc. is more than 10% deviation normal? how do you think about using modified parameters? thanks for any answers! Michael |
#2 |
I think that's pretty good.
34 Hz is only 0.18 octave higher than the rated spec of 30 Hz-pretty close.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#3 |
Gruss Gott
It is within the realm of manufacturing tolerances. Assuming Vas is a bit smaller than spec you will have no problems at all even if you use factory parameters. Best is to use the parameters you measure, however.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Hello...
I am very intrested in this driver 8530K00. If you don'tmind, what are you using it for? Thanks,gcm908 |
#5 |
Wow !!!
I am more than satisfied - This forum is really great !!! Thanks a lot for your immediate replies! (And thanks for the "gruess gott" :-) Using the Scan Speak 8530K00 in my application is a bit curious, but with pleasure I answer your question: Maybe you would expect that I use this excellent driver in combination with a ribbon or electrostatic tweeter, aren't you? :-) The opposite is the case: The Scan Speak provides the low end of a full range Jordan JX53. Cross-over will be at 200-400 according to listening tests, membrane movement and impedance compensation. The reason for this is an existing full wood box and a lower quality woofer to be replaced. However, the full range is rather "quick" and so the Scan Speak might "fit" better to the full range Jordan especially with a flat 6dB cross-over. By the way, I will also replace the Jordan with the new Jordan JXr6 HD. The Scan Speak leaves optically an extraordinary high quality impression. Acoustically I can't say anything yet. With audiophile wishes Michael |
#6 |
If you're within 4Hz, I'm impressed. I love the Vifa P13W. However... Vifa state it has an Fs of 60Hz. Average reality: 75Hz.
| Air Resonance | davidross | Full Range | 15 | 17th April 2009 09:10 PM |
| tonearm resonance | allears | Analogue Source | 2 | 4th April 2008 12:12 AM |
| Confusion about measuring resonance frequency... | jaberwocky6669 | Multi-Way | 21 | 11th June 2006 08:53 AM |
| Frequency CUT and a HOLE in frequency range... | -_nando-_ | Everything Else | 0 | 28th December 2005 08:17 PM |
| resonance in a LCR series | Helix | Everything Else | 1 | 5th February 2002 12:00 AM |
| Page generated in 0.08405 seconds (74.08% PHP - 25.92% MySQL) with 10 queries |
