Hi everybody! I want to construct a 3-way speaker with this drivers:
Low`s - Eminence DELTA 12LF -??-500hZ info Medium`s - Eminence Alpha 6` - 500-4000 hZ info High `s - Eminence APT:80 or 130 ;it`s good?-4000-?????hZ info I looking for any good design for good basses ,may be any standart design with schematics,because I have any attemp in the amp`s ,but in the speakers this is my first project
#2 |
If you have no experience on speaker design, nor suitable measuring equipement, I suggest you take some predesigned system and build that. It's not that easy to create a good speaker by only knowing the drivers you want to use.
If you want a reasonably priced system with good bass you could build for ex. this: http://htguide.com/forum/showpost.ph...&postcount=537 |
#3 |
Landroval thanks for your answer,but i like the futurious outside design like
this . Or may be the classical speakers like this in the attached file. Any other ideas for this drivers configuration.For the making of the speaker i have the assistance of one very good woodworker |
#4 |
Ok. Basically you can design the outside of the speakers to be whatever you want. The look of the drivers is the only thing limiting your creativity. Of cource it's important to keep the internal dimentions of box as designed, but that's rarely an obstacle for creativity.
Here's a list of some sites with good designs among wich you might find a few that pleases you: http://www.rjbaudio.com/projects.html http://www.humblehomemadehifi.com/ http://www.theaudioworx.com/ http://www.htguide.com/forum/forumdisplay.php4?f=6 (Sticky threads) |
#5 |
Any Project concrete ,may be not with The 12LF ,but with any 12" driver and any medium`s,because I can`t select
#6 |
Cal where are you guy
#7 | |
Did it Himself
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#8 |
This is for my little partys -big rooms with 70-80 and many peoples and for a tech-house,tribal,jungle,minimal...
I look for any good design for optimal bass and dimensions and for optimal inside design of the speaker I want a Professional Speakers and only this speakers because his life is very long and because the amp is a Quasy Mosfet with 2x310Watts RMS@8 oHms
#9 |
Speakerholic
I think Landroval is on the right track. If you determine the size and style of box, you can change the outside appearance to suit you.
I think you'll be fine going ahead with the all Eminence system but maybe even consider the APT 150 tweeter versus the 80. I like the dispersion better. Never been a fan of the short round horns. http://www.partsexpress.com/pe/pshow...=290-534&DID=7 You'll probably do OK with 400 and 4000 XO points, min 12dB. Are you planning passive or active? Another choice is the drop it to 200 or 250 and double up on the mids for power handling. Geez now that I think about it, is there any reason you are not going with a 15" low end? |
#10 |
Cal thanks for the fast answer.I think for many project ,but if it`s possible a 2 cameras speaker-1 for the low`s speaker,and one for the meduim`s and for the high,`s because this is my favourite sub design for all times:
Is this design is possible for the Eminence and effective? If you can give me any link because the Dayton 3-ways project from Landroval is too good but I am affraid that i can confuse things
| Looking for a good book on speaker design. | JayH3 | Multi-Way | 1 | 7th June 2008 05:53 AM |
| new speaker baffle design concept...good or not? | thadman | Multi-Way | 4 | 20th November 2006 01:15 AM |
| Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? | XteveX | Multi-Way | 7 | 28th April 2004 04:05 AM |
| Good speaker box design? | SkinnyBoy | Multi-Way | 7 | 23rd July 2003 03:29 AM |
| Is this any good, new DIY design? | tschrama | Pass Labs | 9 | 26th January 2002 06:01 PM |
| Page generated in 0.12103 seconds (78.60% PHP - 21.40% MySQL) with 11 queries |
