Old 12th February 2006, 05:30 AM   #101
el`Ol is offline el`Ol  Germany
The Dayton RS12 are much closer to Peerless XLS or Visaton TIW from their specs than to classic OB drivers. These two have about 2-3 times the excursion, but maybe the conceps without baffle will equally work (low sensitivity, active crossover).
PS:
I asked Tymphany about dipoles some months ago. They say the LAT will also work without baffle (and with low excursion). But here the large moving mass limits sensitivity.
Old 12th February 2006, 07:26 AM   #102
mac is offline mac  United States
mac's Avatar
Originally posted by AJinFLA
Is group delay something that happens when the train is late? ...
I have to laugh.
Old 12th February 2006, 01:35 PM   #103
AJinFLA is offline AJinFLA  United States
Banned
Because of Qts "fight" - I dunno if anyone is still interested in my "Orion for miser" project, but I decided [finally!] what speakers I'm gonna use:
- Seas 27TBFC/G [H1212]
- Seas L22RNX/P [H1252]
- 2xPeerless SLS 12
Lenny, those are excellent choices for an "Oriomiser". Like every loudspeaker system , it is now up to the builder to get the implementation of those drive units: cabinet, crossover,etc. - correctly, to make the design a successful one.
Good luck.
AJ
Old 13th February 2006, 09:50 AM   #104
Originally posted by tade
I am considering putting my dayton rs 12" subs in either u baffles or really nice sealed boxes.
Can you give me some info as to how to think about u baffles? Things like power and frequency response. Maybe a website or something? I am having trouble finding info.
Hello Tade!
This is what I would do with the Eminence (if I had the space):
Height above the driver min. 105, everything in centimeters.
If you mean the Vas 3ft^3 Qts 0.44 version you could try it.
Good luck!
Numbers in the graphics are not readable: 50, 70, 120
Old 13th February 2006, 10:19 PM   #105
tade is offline tade  United States
Send a message via AIM to tade
el`Ol, thank you for the brain power!
What would happen if I omitted the front two wings? Would that put the cancellation null farther back and thus put the listener nearer field?
Anyway, I believe that the size constraints will win over bass goodness. I am looking at building a box 14" by 10" by 30". So, a little more compact! : )
I am getting pretty good at building sealed boxes but ill take any advice you can give me.
Old 14th February 2006, 03:00 AM   #106
Hello Tade! The front wings enhance the acoustic short circuit without making the construction much bigger. I read in a German forum that somebody did this with success.
regards,
Oliver
Old 14th February 2006, 07:17 AM   #107
So el'OL this then becomes similar to a H frame dipole, but without the top piece?
As I see it that would probably give a more open dipole sound than the conventional H frame ... or am I barking up the wrong tree?
Cheers
ALF
Old 14th February 2006, 05:15 PM   #108
Hello Alf!
Since OB bass is more directional than conventional bass the front wings shouldn`t be a problem. Wings on the top should also be no problem.
http://www.auditorium23.de/PHY/Plaene2.html
Old 14th February 2006, 05:20 PM   #109
now, would the front baffles muddy up midbass, about 500hz? I know you can lightly stuff the rear of the baffle, but the front is there for you to hear...
Old 15th February 2006, 06:17 AM   #110
Hello Tade!
If you have the space for two such monsters you can calculate the effect of the conic horn at higher frequencies with Hornresp or others.
One off-topic question, since you are experienced with sealed encosures:
How important is it that a sealed enclosure is really sealed when high-Vas woofers are used (Peerless SLS 12 in my case)?
Regards, Oliver
Dipoles (continued)... Nuuk Multi-Way 10 25th February 2006 08:52 PM
Vas, cms, etc... for Dipoles Raka Multi-Way 21 19th February 2006 06:43 AM
3-way or 4-way dipoles? mazeroth Multi-Way 0 25th January 2006 07:37 AM
SPL max and dipoles XLS Raka Multi-Way 11 21st July 2004 09:34 PM
'T' baffle dipoles sfdoddsy Multi-Way 2 15th January 2003 11:46 AM
Page generated in 0.11579 seconds (76.76% PHP - 23.24% MySQL) with 11 queries
