Old 8th January 2006, 06:44 PM   #1
airman is offline airman  Slovenia
Question changing t/s parameters
I have 2 questions:
1. Suppose i have a loudspeaker. What should i do with it (buying a new one doesn't count ) if i want to increase Fs and also Qts? Is it possible?
2. If i have a loudspeaker with phase plug..what would happen with T/S parameters if i remove phase plug and cover the hole with ordinary dustcap?
thanks.
Old 8th January 2006, 07:09 PM   #2
Did it Himself
richie00boy's Avatar
I doubt you can make Fs higher as that will require lightening the cone. Making it heavier (which lowers Fs) is pretty easy, stick stuff on it. This will also raise Qts.
Changing a phase plug to a dust cap shouldn't affect the T/S parameters. It will affect the sound though.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 8th January 2006, 08:03 PM   #3
If i change the spider with a harder one..that shoul increase Fs..but what would happen with other parameters?
Old 8th January 2006, 08:12 PM   #4
pinkmouse's Avatar
Why do you want to change the T/S parameters? There may be an easier way to achieve what you want.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th January 2006, 08:27 PM   #5
Maybe it is a stupid reason, but..loudspeaker with higher Fs and Qts just sounds better mounted in car door (sort of infinite baffle or very big seald box). Till now i had them in boxes with 8L, but from now on that isn't possible anymore..
Old 8th January 2006, 10:03 PM   #6
thalis is offline thalis  Greece
Cms would of course fall, Vas would fall, Qts would rise. But it’s a difficult surgery to change the spider, you should consider that manufacturers use some special glue, among other things, and that alignment in the gap with your hands isn’t an easy task.
Thalis
Old 9th January 2006, 10:42 AM   #7
I know someone who repairs loudspeakers, so that shouldn't be a problem.
Old 9th January 2006, 11:43 AM   #8
pinkmouse's Avatar
Wouldn't it just be easier to buy new drivers and use your others for something else?
Al
Old 9th January 2006, 12:47 PM   #9
I just wouldn't like to pay much $$$ for new speakers. My old one with this little tweak could also sound much better (or worse )
Old 9th January 2006, 01:09 PM   #10
Tomac is offline Tomac  Croatia
what are the speakers you have and what would you like to get from them?
TS parameters when changing Flux Density f4bok Multi-Way 4 24th December 2008 11:33 AM
TS parameters when changing Flux Density f4bok Pass Labs 2 23rd December 2008 02:46 PM
Changing Lasers Pironi Parts 1 5th February 2008 07:17 PM
Changing ZEN to Ret. of ZEN boq Pass Labs 1 28th May 2004 10:30 AM
Changing BF's for MJE's Bensen Solid State 2 27th May 2003 05:39 AM
Page generated in 0.09341 seconds (74.11% PHP - 25.89% MySQL) with 10 queries
