Old 8th January 2006, 06:44 PM   #1
Default Recycle cabinets
Hate throwing things out - thought I would try a "plop in".
Goal - sound like (better) thean my Paradigm Titans which I really like. I listen to mostly jazz type music - CD/SACD/DVDA. Yamaha RXV2500 100w amp.
Cabinet interior measures 7w x 9.62d x 38h (inches). MTM design. Mid/bass cutouts are 146mm. (VIFA line?) centered 4.5 and 16.5 inches from the top of the cabinet. Tweeter cutout is 52.4mm centered 10.5 inches from the top of the cabinet. Round (front) port is 2.25 inches wide located 12 inches from bottom of cabinet.
I also happen to have crossovers from Mirage om8's. Don't know xover points. Don't know if I can use them.
Drivers, xover and cabinet mod suggestions please.
Old 9th January 2006, 04:37 PM   #2
interior volume works out around 40 litres.
try
http://www.humblehomemadehifi.com/Proteus.html
or
http://speakerbuilder.net/web_files/...oject/eros.htm
as sources for ideas or the solution.
There are many MTM designs to suit all budgets.
/sreten.
Cabinets Coyote Full Range 26 7th June 2009 03:16 PM
recycle BGW 750 for new amp damage Solid State 3 10th August 2008 12:02 PM
Recycle an Eico HFT-90 for a preamp pchw Tubes / Valves 5 30th May 2007 12:10 PM
Page generated in 0.07031 seconds (69.23% PHP - 30.77% MySQL) with 10 queries
