I have some 2 way PA speakers that I want to make a jack plate setup for. Right now the speaker is setup with a 1/4" jack for the woofer and a 1/4" jack for the tweeter (bi amp only). I want to be able to switch between bi amp and conventional internal crossover setup using a switch. When the circuit is in Parallel mode I want the two jacks to be Parallel. I’m not sure whether its okay to common the negatives in the circuit to save the hassle of switching them. Take a look at my diagram so far if its a “Big No No” to combine negatives I think it would be good to know before proceeding. The XO is the crossover in the image.
#2 |
Speakerholic
For some reason I can't see the image right now
#3 |
[img=http://img217.imageshack.us/img217/5662/jackplatesetup6xz.jpg]
guess i cant use facebook to host photos |
#4 |
#5 |
Switch both. That will make sure you never have any explosions if you use a bridged amp.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| My custom sub box | audiobahnkid592 | Car Audio | 4 | 13th March 2007 04:19 PM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| Page generated in 0.07096 seconds (84.51% PHP - 15.49% MySQL) with 10 queries |
