I posted this question in the full range forum so pardon the double post.
Had an idea of doing a bipole line array using a Hi Vi BS3 3" inch full range driver using 5 or 6 in the front and 5 or 6 in the back with the bottom half of the enclosure filled with sand for stability. I realize there will be some comb filtering issues but are there any other issues to consider that would not make this a formidable project? They would be crossed over to a sub and I might use an EQ to smoothen things out depends on the final outcome. Also was wondering if I should cross the rear drivers over down lower to improve the overall baffle step effect. What do you guys think? |
#2 |
I also posted a shorter ersion of this reply in the full-range section. Lobing problems will probably occur -I don't know these drivers, do you have a link? Depends on how large they are. 3" or over and it's definate I would say. Smaller, and you might get away with it, but that's a very short line -too short to be worth the effort I suspect, though i speak under possible (probable) corection.
Going bipolar will remove baffle-step problems, but other than that I'm not sure of any benefits in this particular case. Dave, Jim (resident bipole and line-array experts respectively), any thoughts or suggestions? I'd be interested in finding out myself to be honest. Best Scott |
#3 |
I just came across the linaeum concept (a bipolar supertweeter, related to a ribbon). It is in the price range of a soft dome, not really cheap in a line array, but definitely cheaper than ribbons. The bipolar version is said to be sold by radioshack, but I didn`t find it, just complete speakers. Aurasound have a closed version.
regards, Oliver |
| Full range line array | inrank | Full Range | 39 | 20th January 2009 12:27 PM |
| full range driver bipole line array idea. | fazman | Full Range | 1 | 6th January 2006 11:21 AM |
| Full-range line array? | mazeroth | Full Range | 20 | 1st November 2004 03:47 PM |
| line array with full range drivers? | leadbelly | Multi-Way | 9 | 25th January 2003 04:48 PM |
| Page generated in 0.08026 seconds (70.63% PHP - 29.37% MySQL) with 10 queries |
