I have about 12l to play with in my current design, could go a bit larger but nothing huge. so can I do anything with this driver apart from sealed with a Linkwitz transform? would just sealed work well? I have no experience of using this driver yet.
#2 |
Sealed in a 12 liter will give you an F3 of about 60 hz, and a Qtc of close to .7. This is from my own actual TS measurements.
Be sure you use that in a three way. It's not a driver friendly to 2-way operation at all.
-Zaph|Audio- |
#3 |
Well its going in a 2 way but with a wide band 'tweet' Xover will be possibly be 150Hz 1st order, or there abouts.
#4 |
While I remember, I pulled one of the phase plugs out (ham fisted curiosity
I'm thinking, this driver has enough mechanical excursion for the coil to come completely out of the motor! now surely I have an issue with the VC having a pole piece through it on the instroke and nothing on the out stroke, so changing the VCs inductance. Would there be any benefit in replacing the phase plug with a non magnetic metallic replacement? |
#5 | |
You've broke my drivers! Don't even think of asking for a refund now |
#6 |
its not broken, its just doubling up as a jigsaw puzzle
I wanted to see if you could remove the phase plugs as IMHO they make the drivers look a bit cheap in comparison to say the Excel units. I was possibly planning on making aluminium or stainless steel replacements and anodising or powder coating them, just for asthetics (I can be so vain sometimes |
#7 | |
| Seas 27TDFC H1189 vs Seas 27TFFC H881 | ermes | Multi-Way | 4 | 19th April 2011 01:20 PM |
| chooseing Seas Cygnet or others seas kits | juanito | Multi-Way | 0 | 20th July 2009 12:27 PM |
| Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. | Spasticteapot | Swap Meet | 2 | 7th March 2007 04:06 PM |
| Seas L22RN4X, CA21REX woofers, Fountek NeoCd3.0R Ribbons, W3-871, DA175 | omarmipi | Swap Meet | 8 | 17th July 2006 10:17 PM |
| Seas 27TDFC Tweeters & L22RN4X Woofers | omarmipi | Swap Meet | 1 | 19th June 2006 10:35 PM |
| Page generated in 0.08188 seconds (75.17% PHP - 24.83% MySQL) with 10 queries |
