Old 5th January 2006, 09:22 AM   #1
Default First effects of thympany-fusion
Hi all,
Look at the tymphany home page.............
I have a very bad presage for the future.
Inertial
Old 5th January 2006, 01:38 PM   #2
ShinOBIWAN's Avatar
Sad day,
Vifa's identity has been wiped out by some Peerless v-line rubbish.
They also massively scaled back the Vifa range - take a look and there's only 3 tweeters now and a handful of midbass and woofers.
Time will tell if they kill the brand completely or if they introduce new products. Its not looking good though because both Scanspeak and Peerless have new product announcements for 2006 but nothing from Vifa, make of that what you will.
Old 5th January 2006, 01:51 PM   #3
ucla88 is offline ucla88  Tahiti
Originally posted by ShinOBIWAN
Sad day,
Go over to the MAD board and search some of Ken Kantor's posts for the reasons behind the name change. It does look like the lineup has been pruned though.
Old 5th January 2006, 02:34 PM   #4
AJinFLA is offline AJinFLA  United States
Banned
Well, about the only thing I was crushed to see was the absence of the Vifa Aluminum 10" sub, one of the lastest from Vifa. The DX19 had good potential IMHO also.
However, I was delighted to see what appears to be new Alu. cone woofers in the Peerless line up. This one looks rather interesting. They have completely eliminated distortion!
http://www.tymphany.com/datasheet/printview.php?id=146
Time will tell of course.
AJ
p.s. the 4mm xmax is obviously a typo. The 12 says 12.5mm.
Old 6th January 2006, 02:50 AM   #5
ShinOBIWAN's Avatar
AJ
The XT19 and PL18's have gone too
The new alu XXLS's look great but I prefer the one with the black dust cap. Wonder how these stack up against the very good Dayton Reference subs?
EDIT: Looking at the specs, I don't believe these will be as useful for lowdown bass as the current XLS's and Dayton Reference. The Fs is nearly 36hz and the rest of the TS don't really scream anything interesting. Looks to me like a car woofer this one.
Old 6th January 2006, 08:38 AM   #6
IMHO product streamlining is good.
As for the website, it must be undergoing some kind of transition period.
The last time I check some drivers had been placed into the wrong categories eg. SS 13M8636 was classed as "Revelator" and SS 15M4531K was classed as "Classic" (it should be the other way around)
If you check now the XT19 and PL18 are indeed there. The PL18 is found in the Vifa/Peerless Vline woofer section, even though is definitely a midwoofer.
Reason for the name change
Old 6th January 2006, 10:26 AM   #7
ShinOBIWAN's Avatar
Thanks Tk,
It looks as if your right about the website as it seems to be undergoing maintanance.
Fusion Hybrid 300B otto88 Tubes / Valves 5 24th October 2008 04:39 AM
Fusion FP-505: TIP36C Problem theAnonymous1 Car Audio 17 27th May 2008 07:26 PM
Fusion Amp Tom7227 Car Audio 1 29th May 2007 09:02 PM
FS: Tannoy Fusion 4 Floorstanders Mo'Reece Swap Meet 1 3rd March 2005 11:17 AM
Fusion-jazz plysch Music 1 18th April 2004 09:27 PM
Page generated in 0.10474 seconds (76.20% PHP - 23.80% MySQL) with 10 queries
