Been looking at high passing midbass at around 150Hz and was getting a very uneven response due to the resonant impedance peak. The aim was to reduce excursion (Full range driver so low XMAX) but the impedance peak was making the high pass ineffective (simple 1st order filter, single cap) and not reducing the excursion.
So my idea is to do an Aperiodic/MAPD enclosure to flatten the impedance and act as a high pass filter, then tune it further with the cap (which is now more predictable due to the flatter impedance curve). Anyone else done this? anyone see any problems that I've missed? |
#2 |
I had the same dilemma.
The way I got around it is to use a 2nd order highpass. The shunt L acts to supress the impedance hump and if L is big enough, it's close to a 6dB highpass filter around fc (actually it's a low Q 2nd order) . |
#3 |
I think I saw a design somewhere in this forum a few months ago. It requires different tweeking. Much different from the main steam designs.
Hear the real thing! |
#4 |
The aperiodic enclosure will reduce the resonant peak, but it will still end up being higher in frequency and amplitude than the free air resonance of the driver.
If you really want toget rid of it and still use a 6db/oct xover cap, then stick an RLC circuit across the driver terminals. F= 1/ 2pi * (sqrt LC) and the resistor is approx Re. So if you're resonance peak is at 80Hz, you could use a 8mH coil and 500uF cap. The coil can be small gauge laminate core, and the cap can be electrolytic to keep the cost reasonable. Or do like David suggested. |
#5 |
Tobe honest the higher resonant frequency isn't a problem. The peak is about 100Hz, Fs is quoted at 65Hz and I want to low pass them about 150-300Hz (depending what sounds good) so the rise in frequency of the resonance isn't really a problem.
the aperiodic box, reduces the resonant peak and pushes up it frequency, this isn;t a problem for my aim, am I missing something (being full range I'd like to keep electronic components to a minimum). |
#6 |
There seems to be a patent based on a Symetric Air Friction. Maybe that might work. The patent is really old, over 20 years. I first saw it in Popular Mechanics. Very Interesting. It sort of makes lots of turns while expanding and reducing cross section area to act as low pass filtering I think, but also adds damping to the driver.
#7 |
I guess I don't understand what the problem is with a Zobel.
None of the components are in the signal path and should create very minimal distortion of the signal itself. |
| tuning aperiodic vents | the full ranger | Multi-Way | 9 | 18th November 2009 09:22 PM |
| Active vs. passive Xovers | Ryan_Mc | Multi-Way | 14 | 5th November 2008 03:31 AM |
| Aperiodic Vents | MykeysToy | Multi-Way | 10 | 9th March 2008 07:42 PM |
| Capacitors for passive xovers. | JoeBob | Multi-Way | 1 | 14th December 2001 01:46 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.10492 seconds (78.58% PHP - 21.42% MySQL) with 10 queries |
