Just been doing a bit of digging & haven't found what I'm after - just wondering if anyone's had any degree of success with paper mache for a speaker enclosure? I know it immediately evokes memories of nursery/kindergarten mayhem, and that well-built matronly woman that.. ahem; but there's more than one way of making and using the stuff. Go look at any antiqueties site & some of the stuff they used to make was really tough and could be intricate too. Couple this with modern adhesive phases (i.e. PVA, resin, good 'ole wallpaper paste etc) surely the possibilities are endless. Would have thought that a 3D composite would be a doddle too. Any thoughts?
Cheers - Fezz
Idlers ROCK! |
#2 |
Not the same thing as a speaker but...
Soundquality of papier-mache was proven good a long time ago: About 150 years ago Antonio Torres, the grandfather of the classical guitar, made a great sounding classical with back and sides made of papier-mache. |
#3 |
ah.. that kind of mictuates on my strawberries - surely a guitar or violin needs a resonator. Hm.
I was thinking of a number of possibilities: 1) Modular TL components 2) Composites - use 3D configurations to make "aerolam" type structures in any shape you like; get a sphere, plaster it up, cut 1/2" paper straws & stack 'em all over, stick another coat or "skin" on the outside. You can play around with the relative densities & impregnate with anything you like!
Idlers ROCK! |
#4 |
Here's an idea - dead simple. couple of pipes close together with sides stuck on makes a mould. Pulp mache can be poured dtraight in to make TL sections. Wait 'till dry & cut to size.
Idlers ROCK! |
#5 |
Paper mache huh, could work.
I saw a guy build a perfect sphere out of concrete for a sub. It broke before testing could be done.
| Casting papier-mache as speaker enclosures | Moondog55 | Multi-Way | 30 | 18th February 2010 10:38 PM |
| Paper... | mikeks | Solid State | 24 | 6th January 2007 07:18 AM |
| This paper...anyone? | mikeks | Solid State | 6 | 18th January 2005 05:12 PM |
| amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? | siu sin man tho | Digital Source | 0 | 17th March 2004 12:31 PM |
| op. amp. paper...? | mikek | Solid State | 9 | 27th June 2003 04:18 PM |
| Page generated in 0.08091 seconds (76.83% PHP - 23.17% MySQL) with 11 queries |
